To start integrating Typeform with GoHighLevel, you first need to access Pabbly Connect. Open your browser and go to pabbly.com/connect. If you’re a new user, click on the “Sign up for free” option in the top right corner.
Once you sign up, you will receive 100 free tasks each month to explore Pabbly Connect. This means you can create up to 100 automations for free, allowing you to test the integration capabilities of the platform.
After logging into Pabbly Connect, navigate to the workflow builder. This is where you will set up your automation between Typeform and GoHighLevel. Click on the “Add Trigger” button to begin.
- Select Typeform as your trigger application.
- Choose the event “New Entry”.
- Click on “Connect” to establish the connection.
Ensure that you are logged into your Typeform account to provide necessary permissions. After connecting, select the specific form you want to automate, such as the registration form, and click “Save and Send Test Request” to capture the webhook response.
3. Capturing Webhook Response from Typeform
Once you have set up the trigger in Pabbly Connect, it will wait for a webhook response. To capture this response, open your Typeform and submit a test entry.
After submitting the form, go back to your workflow in Pabbly Connect. You should see that it has successfully captured the response, displaying all the details you entered, such as name, email, and phone number.
4. Adding Action Step to Connect with GoHighLevel
Next, you will need to add an action step to send the captured data to GoHighLevel. In Pabbly Connect, click on “Add New Action Step” and select “Lead Connector” as your action application.
- Choose the event “Create or Update a Contact”.
- Click on “Connect” to link it with GoHighLevel.
- Select your sub-account for GoHighLevel.
Make sure you are logged into your GoHighLevel account to grant the necessary permissions. After connecting, map the fields from the Typeform response to the corresponding fields in GoHighLevel.
5. Testing the Integration in Real Time
Once everything is set up in Pabbly Connect, it’s time to test the integration. Submit another entry through your Typeform to see if the data is correctly added to GoHighLevel.
After submitting the form, refresh your GoHighLevel contacts list. You should see the new contact added with the details you entered. This confirms that the automation is functioning correctly, allowing you to create a new contact in GoHighLevel every time a new entry is submitted in Typeform.
In this tutorial, we demonstrated how to integrate Typeform with GoHighLevel using Pabbly Connect. This powerful automation tool allows you to streamline your workflows and enhance productivity by connecting your favorite applications seamlessly. Try it out today and experience the benefits of automation!
