To start integrating WhatsApp with your website, first, you need to access Pabbly Connect. This platform acts as the central hub for all your integration needs, allowing you to connect various applications seamlessly.
Begin by visiting the Pabbly website. If you are a new user, click on the “Sign Up Free” option to create an account. Existing users should simply log in to access the dashboard. Once logged in, navigate to the Pabbly Connect section to start setting up your integration.
2. Creating a WhatsApp Assistant Using Pabbly Connect
After accessing Pabbly Connect, the next step is to create your WhatsApp assistant. This assistant will respond to user queries in real-time, mimicking human-like interactions.
To create the assistant, click on the “Add Assistant” button. You will be prompted to name your assistant according to your business needs. Here are the steps to follow:
- Click on “Add Assistant”.
- Enter a name for your assistant.
- Select the instruction type to define how the assistant behaves.
Once you have set the instructions, you can adjust the temperature settings to control the creativity level of your assistant. A lower temperature will yield more stable responses, while a higher temperature allows for more creative replies.
3. Configuring the API Key for Pabbly Connect
To enable your WhatsApp assistant to function properly, you must configure the API key through Pabbly Connect. This key connects your assistant to the OpenAI platform.
Follow these steps to obtain your API key:
- Visit the OpenAI API keys page.
- Click on “Create New Secret Key”.
- Copy the generated API key and paste it into Pabbly Connect.
Once you have entered the API key, click on the “Connect” button to save your settings. This step is crucial as it allows your assistant to access the OpenAI services for generating responses.
4. Uploading the Knowledge Base in Pabbly Connect
For your WhatsApp assistant to provide accurate responses, you need to upload a knowledge base file through Pabbly Connect. This file contains all the necessary information about your business.
To upload the knowledge base, follow these steps:
- Click on “Add New File”.
- Select a file in .txt or .pdf format (size limit: 90 MB).
- Ensure the file contains all relevant business data.
This knowledge base acts as the brain of your assistant, enabling it to provide specific and accurate replies to user inquiries.
5. Embedding the WhatsApp Assistant into Your Website
Finally, to make your WhatsApp assistant live on your website, you need to embed it using Pabbly Connect. This will allow users to interact with the assistant directly from your site.
Here’s how to embed your assistant:
- Click on the “Embed” option in Pabbly Connect.
- Copy the provided embed code.
- Paste the code into your website’s HTML before the closing script tag.
After saving the changes, refresh your website to see the assistant in action. It will now provide instant responses to user queries, enhancing user experience and engagement.
This tutorial covered how to integrate WhatsApp using Pabbly Connect for automated responses. By following the steps outlined, you can create a WhatsApp assistant that interacts with users effectively, enhancing customer service.
