To start automating your contact management, access Pabbly Connect by visiting pabbly.com/connect. If you’re a new user, click on ‘Sign Up for Free’ to create your account. Existing users can log in directly to their dashboard.
Once logged in, you can explore the workflow builder. This is where the magic happens, allowing you to create automated workflows between applications like Google Sheets and Zoho CRM. You can try Pabbly Connect for free, allowing you to create up to 100 tasks monthly.
2. Setting Up Google Sheets Trigger in Pabbly Connect
In this step, we will set up a trigger in Pabbly Connect using Google Sheets. Click on the ‘Add Trigger’ button and select Google Sheets as your application. Choose the event ‘New or Updated Spreadsheet Row’ for capturing new entries.
After selecting the event, connect your Google Sheets account. You will receive a webhook URL. Copy this URL and proceed to your Google Sheets to set up the Pabbly Connect Webhook extension. Follow these steps:
- Go to Extensions > Add-ons > Get Add-ons.
- Search for Pabbly Connect Webhooks and install it.
- Refresh your spreadsheet to see the new option under Extensions.
Once installed, navigate to Extensions > Pabbly Connect Webhooks > Initial Setup. Paste the webhook URL and specify the trigger column, which is crucial for data transfer.
3. Mapping Data to Zoho CRM Using Pabbly Connect
Now that you have set up the trigger, it’s time to configure the action step to map data from Google Sheets to Zoho CRM using Pabbly Connect. Click on ‘Add Action Step’ and select Zoho CRM as your action application. Choose ‘Create Contact’ as the event.
Connect your Zoho CRM account by providing the required domain. Once connected, you will need to map the fields from the Google Sheets data to Zoho CRM. This is done by selecting the appropriate fields based on your spreadsheet’s data structure. Mapping allows the data to be dynamic, updating automatically with new entries.
- Select lead source and fill in required fields.
- Map first name, last name, and email using the mapping feature.
- Click on ‘Save and Send Test Request’ to verify the connection.
After saving, check your Zoho CRM to confirm that the contact has been created successfully. This confirms that Pabbly Connect has facilitated the data transfer effectively.
4. Sending Bulk Data to Zoho CRM
To send multiple contacts from Google Sheets to Zoho CRM, we can utilize the bulk action feature in Pabbly Connect. After confirming that the single contact was created, go back to your Google Sheets and navigate to Extensions > Pabbly Connect Webhooks.
Click on ‘Send All Data’ to transfer all contact details from your spreadsheet to Zoho CRM. This action will create multiple contacts in one go, eliminating the need for manual entry. Ensure your spreadsheet is organized correctly to avoid any data discrepancies.
Additionally, if you want the automation to trigger every time new data is added, enable the ‘Send on Event’ option in the same menu. This will ensure that Pabbly Connect continuously updates your Zoho CRM with new entries from your Google Sheets.
5. Conclusion
Integrating Google Sheets with Zoho CRM using Pabbly Connect streamlines your contact management process. By following the steps outlined in this guide, you can automate the addition of multiple contacts without manual intervention.
This not only saves time but also ensures accuracy in your CRM data. Experience the power of automation with Pabbly Connect today, and enhance your productivity significantly.
