To begin using Pabbly Connect, you must first access the platform. You can do this by visiting the Pabbly website and signing up for an account. Once registered, you will receive 100 free tasks every month to explore the software.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can create and manage your automation workflows. Click on the “Create Workflow” button to initiate the process of connecting Google Sheets to ChatGPT.
In this section, we will create a new workflow using Pabbly Connect. After clicking on the “Create Workflow” button, you will see options to create from scratch or use a quick builder. Choose the option that suits your needs.
  • Select “Create from Scratch” to begin your workflow.
  • Name your workflow, for example, “Connect Google Sheets to ChatGPT for Bulk Data Processing”.
  • After naming, click the “Create” button to proceed.
Your workflow is now created, and the next step is to set up the trigger for this automation.
3. Setting Up the Trigger with Google Sheets
To automate the process, you need to set up a trigger in Pabbly Connect. This trigger will activate whenever a new record is added to Google Sheets. Select Google Sheets as your trigger application and choose the event “New or Updated Spreadsheet Row”.
Click on the “Connect” button, and a webhook URL will be generated. Copy this URL, as it will be used to connect Google Sheets with Pabbly Connect. Go to your Google Sheets, navigate to “Extensions”, then “Add-ons”, and install the Pabbly Connect Webhooks add-on.
4. Connecting Google Sheets to Pabbly Connect
After installing the Pabbly Connect Webhooks add-on, you will need to set it up. Click on the add-on and select “Initial Setup”. Paste the webhook URL you copied from Pabbly Connect into the designated field.
  • Specify the trigger column, which is the last data column where new records will be added.
  • Click the “Send Test” button to verify the connection.
  • Ensure the “Send on Event” toggle is enabled for real-time updates.
Once the setup is complete, you will see that the connection between Google Sheets and Pabbly Connect is functioning properly.
5. Generating Reports Using OpenAI
The final step in this integration is to connect OpenAI to Pabbly Connect. Select OpenAI as your action application and choose the event “Generate Response Using Text Input”. You will need to create a new connection by providing your OpenAI API key.
Once connected, map the fields from Google Sheets to OpenAI. This mapping allows the system to dynamically pull data from your Google Sheets for report generation. Finally, select Gmail as your next application to send the generated report to the manager.
This tutorial has guided you through the process of integrating Google Sheets with ChatGPT using Pabbly Connect for bulk data processing. By setting up triggers and actions, you can automate report generation and streamline your workflow efficiently.
