To connect Claude with Pabbly Connect, start by accessing the Pabbly Connect platform. Simply open a new tab and navigate to Pabbly Connect at pabbly.com/connect. This powerful tool allows you to automate tasks and connect various applications seamlessly.
Once on the homepage, click on the “Free Sign Up” button to create an account. After entering your basic details, you can log into your dashboard. From here, you can begin creating your automation workflows using Pabbly Connect.
2. Creating a Workflow with Claude in Pabbly Connect
After logging into Pabbly Connect, the next step is to create a workflow using Claude. Click on the “Create Workflow” button on your dashboard. You will then need to select Claude as your agent for this automation.
  • Click on “Create Workflow”.
  • Choose Claude as the agent.
  • Copy the server link provided.
Next, open the Claude connectors and paste the server link you copied earlier. This step is crucial as it connects Claude to Pabbly Connect, enabling the automation process.
3. Setting Up Claude Connectors in Pabbly Connect
Once you have pasted the server link, navigate to the connectors section and click on “Add” to create a custom connector. Name your connector, for example, “Pabbly Connect”. This name will help you identify the connector later.
After naming your connector, click on the “Continue” button. You will be prompted to grant several permissions. Make sure to allow these permissions as they are necessary for Pabbly Connect to function correctly with Claude.
4. Automating Tasks with Pabbly Connect and Claude
With the connector set up, it’s time to automate your tasks. Start by creating a new chat in Claude and describe your desired workflow. For instance, you might want to automate meeting bookings through Calendly.
  • Specify your request clearly in the chat.
  • Mention all applications involved: Google Sheets, Slack, etc.
  • Allow Claude to process your request and create the workflow.
Claude will then ask for permissions to finalize the automation. Grant these permissions, and Pabbly Connect will automatically generate the workflow based on your specifications.
5. Finalizing Your Workflow in Pabbly Connect
After Claude has created the workflow, you will see all steps outlined clearly. This includes adding meeting details to Google Sheets, sending notifications via Slack, and updating Google Contacts. Review the workflow to ensure everything is correct.
Once satisfied, save the workflow in Pabbly Connect. Now, every time a meeting is booked through Calendly, the automation will trigger, ensuring all necessary actions are taken without manual intervention.
In this tutorial, you learned how to connect Claude with Pabbly Connect to build effective automations. With Pabbly Connect, integrating various applications becomes effortless, allowing you to streamline your workflows efficiently.
