1. Accessing Pabbly Chatflow for Integration
To start integrating Pabbly Chatflow with Heaven Stone Reality, you first need to access the platform. Navigate to Pabbly Chatflow by entering the URL chatflow.pabbly.com in your browser. This will take you to the dashboard where you can begin setting up your WhatsApp chatbot.
Ensure that your WhatsApp number is linked to your Pabbly Chatflow account. If you need guidance on linking your WhatsApp, refer to the video tutorial provided. Once linked, you can proceed to create your chatbot flows.
2. Creating a Chatbot Flow in Pabbly Chatflow
Once you are on the dashboard of Pabbly Chatflow, select “Flows” from the left-hand menu. This will lead you to the page where you can create your chatbot flow. Here, you will find options for various triggers that initiate your chatbot’s responses.
- Choose a trigger event, such as keyword matching.
- Set the keyword that activates the chatbot, e.g., “Hello”.
- Create message blocks to respond to user inquiries.
After selecting your trigger and setting the keywords, you can create message blocks that will respond to users. This is essential for automating your WhatsApp interactions through Pabbly Chatflow.
3. Adding Media and Welcome Messages
In this step, you will enhance your chatbot by adding media and a welcome message. Use the drag-and-drop feature to insert a media block into your flow. Choose the type of media you want to send, such as an image.
- Upload the image from your media library.
- Add a welcome message to greet users when they interact with your chatbot.
- Include buttons for user actions, like “Find Property”.
These features will make your chatbot more engaging and user-friendly. The welcome message and media will be sent automatically when a user triggers the bot, showcasing the capabilities of Pabbly Chatflow.
4. Handling User Queries with AI Integration
To effectively manage user queries, you need to integrate an AI assistant into your Pabbly Chatflow setup. This allows the chatbot to respond intelligently based on user input. Start by adding a question block that prompts users for their property requirements.
Next, set up a custom field to store user responses. This will enable the AI to access and utilize this data when providing answers. By using a smart assistant, your chatbot can give personalized responses based on the user’s needs, enhancing the user experience.
5. Finalizing and Saving Your Chatbot Flow
After completing the setup of your chatbot flow in Pabbly Chatflow, ensure to save your work. Click the save button to finalize your integration. This step is crucial as it secures all the configurations you’ve made.
Once saved, your chatbot will be ready to handle queries from users effectively. By using Pabbly Chatflow, you have automated your WhatsApp interactions, making it easier for clients to receive timely responses.
In this tutorial, we demonstrated how to use Pabbly Chatflow to integrate with Heaven Stone Reality and AI. By following these steps, you can create an efficient WhatsApp chatbot that automates client interactions seamlessly.
