To integrate Pabbly, Google, and Google Ads, first, you need to access Pabbly Connect. Open a new tab and search for pabbly.com/connect to reach the Pabbly Connect landing page.
Click on the “Sign Up for Free” button. You’ll be asked for basic information, and no credit card details are required. After filling out the form, your free trial will be activated, allowing you to log in and access the dashboard.
Once logged into Pabbly Connect, navigate to the dashboard. Click on “Create Workflow” and select “Build Workflows with Cloud or Chat GPT”. Choose Chat GPT as your agent for automation.
Next, you’ll need to add a plugin for Pabbly. Copy the provided URL and open the Chat GPT plugins section. Here, click on “Add” and then “Add Custom MCP Server”. Enter the tool name as Pabbly Connect and proceed.
  • Enter a description if desired.
  • Agree to the terms and conditions.
  • Click on “Create as a Plugin”.
After a brief wait, your plugin will be created. Ensure you don’t close the window while it processes your request.
3. Automating Leads from Google Ads
Now that you have set up the plugin, it’s time to automate the lead capture process from Google Ads using Pabbly Connect. Start a new chat and select the Pabbly Connect Test plugin you created earlier.
Paste your prompt for automation. For instance, you can instruct it to create an automation for new leads coming from Google Ads. Once you send this prompt, Pabbly Connect will process the request and generate the workflow.
  • Provide the link to the Google Form or Sheet.
  • Specify the Slack channel for notifications.
  • Include WhatsApp messaging details.
Once the workflow is generated, you will receive a webhook URL to capture test responses. This is essential for the next steps in your automation.
4. Testing and Capturing Responses in Pabbly Connect
With your workflow ready, the next step is to test the automation by capturing responses through Pabbly Connect. Use the webhook URL provided to send test data from your Google Ads leads.
When you capture the test response, Pabbly Connect will automatically update the workflow with the necessary actions. Follow the prompts to ensure that all details are correctly processed.
  • Confirm the details received from Google Ads.
  • Make sure that notifications are sent to Slack and WhatsApp.
  • Check that the lead is added to Google Contacts and Sheets.
This step ensures that your automation is functioning correctly, allowing you to manage leads effectively.
5. Finalizing Your Automation with Pabbly Connect
After successfully testing the workflow, it’s time to finalize your automation within Pabbly Connect. Review all the settings and ensure that each action is set up correctly according to your requirements.
Once everything is confirmed, you can activate the workflow. This will allow Pabbly Connect to automate the entire process, from capturing leads in Google Ads to notifying your team on Slack and WhatsApp.
Remember, with Pabbly Connect, you can easily create complex automations without needing extensive technical knowledge. This platform simplifies the integration process, making it accessible for everyone.
In conclusion, using Pabbly Connect to integrate Pabbly, Google, and Google Ads streamlines your workflow and enhances productivity. By following these steps, you can automate lead management effortlessly.
