To start integrating Key and API Key, first access Pabbly Connect by visiting pably.com/connect. Here, you can sign up for a free account, allowing you to execute up to 100 tasks monthly without any cost.
Once signed up, you’ll be ready to create your automation workflow. This initial setup is crucial for linking your applications through Pabbly Connect.
2. Setting Up Google Sheets with Pabbly Connect
The first step involves configuring Google Sheets to work with Pabbly Connect. You need to create a new Google Sheet and prepare it to capture data automatically.
  • Open your Google Sheets and create a new spreadsheet.
  • Install the Pabbly Connect Webhooks add-on from the Google Workspace Marketplace.
After setting up the Webhook, paste the URL into the add-on settings of your Google Sheet. This configuration allows Pabbly Connect to capture new entries automatically.
3. Capturing Ideas in Google Sheets
With your Google Sheet ready, the next step is to ensure that any new idea added to the sheet triggers an action in Pabbly Connect. This is done by setting the trigger column to capture data from Column A.
Once the trigger is set, you can test the integration. Add a new idea to your Google Sheet, and Pabbly Connect will automatically capture it. This seamless connection allows for real-time data processing.
4. Integrating OpenAI with Pabbly Connect
The next step is to integrate OpenAI with Pabbly Connect, enabling you to generate images based on the ideas captured in Google Sheets. In Pabbly Connect, you will add a new connection and provide your OpenAI API Key.
  • Navigate to OpenAI and generate your API Key.
  • Paste the API Key into the connection settings in Pabbly Connect.
  • Write a prompt that describes the image you want to generate.
By mapping the previous step’s data, you ensure that every new idea generates a corresponding image through OpenAI, all managed by Pabbly Connect.
5. Updating Google Sheets with Image URL
Finally, after generating the image, you want to update your Google Sheet with the new image URL. Using Pabbly Connect, you can easily connect to Google Sheets again to add this URL to the appropriate cell.
Log in to Google through Pabbly Connect, select the appropriate spreadsheet, and map the image URL to the designated column. This ensures that every generated image is recorded systematically.
In this tutorial, you’ve learned how to use Pabbly Connect to integrate Key and API Key effectively. By following these steps, you can automate your workflow without any coding skills required. This setup allows you to generate images based on ideas captured in Google Sheets seamlessly.
