To build an AI-powered WhatsApp bot, start by accessing Pabbly Connect. This integration platform allows you to connect various applications seamlessly.
Visit the Pabbly Connect website and sign in or sign up for a free account. Once logged in, you can begin setting up your integration with WhatsApp and the AI assistant.
2. Setting Up Your AI Assistant with Pabbly Connect
After logging into Pabbly Connect, navigate to the AI assistant setup page. Here, you will create your assistant that automates customer interactions.
- Select the AI agent instruction type.
- Configure the AI temperature setting for response creativity.
- Enter your OpenAI API key to enable AI functionalities.
Once these settings are configured, you can save your AI assistant setup. This is crucial for integrating with WhatsApp through Pabbly Connect.
3. Configuring the Knowledge Base for Your AI Assistant
Your AI assistant requires a knowledge base to respond accurately to customer queries. This base contains essential information about your business.
Upload your knowledge base document in either TXT or PDF format via the media library in Pabbly Connect. Select the uploaded file to ensure your AI assistant has the necessary data to assist customers effectively.
- Provide a clear business overview in the knowledge base.
- Include common customer queries and responses.
- Ensure the document is well-structured for easy understanding.
With the knowledge base configured, your AI assistant can now provide accurate answers to customer inquiries, enhancing the overall customer experience.
4. Finalizing Your AI Assistant Setup
After configuring the knowledge base, it’s time to finalize your AI assistant. In Pabbly Connect, you can customize the visual appearance and settings of your assistant.
Set your header and footer text, choose a theme, and enable or disable specific features like the “Powered by Pabbly” label. Once you’re satisfied with the setup, activate the assistant by toggling the enable button.
- Customize the initial message for users.
- Embed the assistant on your website if needed.
- Save all settings to ensure they take effect.
By completing these steps, your AI assistant is now fully operational, ready to assist customers on WhatsApp through Pabbly Connect.
5. Enabling Your AI Assistant for Customer Interactions
To enable your AI assistant for customer interactions, navigate to the inbox settings in Pabbly Connect. Here, you can choose whether to enable the assistant for all contacts or specific ones.
Select the AI assistant you created and save the settings. This will allow the assistant to respond automatically to customer inquiries on WhatsApp, ensuring timely responses.
- Ensure auto-replies are enabled for smooth operation.
- Test the assistant by sending a message to your WhatsApp number.
- Monitor interactions to refine responses as needed.
With these settings in place, your AI assistant is now live, ready to handle customer queries efficiently through Pabbly Connect.
By following this guide, you can easily set up an AI-powered WhatsApp bot using Pabbly Connect. This integration enhances customer support and sales processes, ensuring timely responses to inquiries.
