To start building AI automations using Pabbly Connect, first, access the Pabbly website. Navigate to the Pabbly Connect landing page where you can sign up for a free trial. This allows you to explore the features of Pabbly Connect without any initial cost.
Once logged in, locate the workflow builder. Click on the “Add Trigger” button to begin setting up your automation. Select “Google Sheets” as your application, and choose the event “New and Updated Spreadsheet Row”. This sets the stage for integrating Google Sheets with Pabbly Connect.
2. Setting Up Google Sheets Trigger in Pabbly Connect
After selecting the trigger, you will receive a webhook URL. Copy this URL and head to your Google Sheets. You need to install the Pabbly Connect WBx add-on to facilitate this connection. Go to “Extensions”, then “Add-ons”, and search for Pabbly Connect WBx to install it.
  • Open your Google Sheets and refresh it after installation.
  • Navigate to the Pabbly Connect WBooks extension tab.
  • Click on “Initial Setup” and paste the webhook URL.
Specify the trigger column, which is the last column where data will be entered. After submitting, click on the “Send Test” button to ensure the connection works. This successfully links your Google Sheets with Pabbly Connect.
3. Generating Captions Using GPT-6
With Google Sheets connected, the next step is to generate captions using GPT-6. Click on the “Add Action” button in your workflow and select “OpenAI” as the application. Choose the event “Chat GPT” to proceed.
Connect to OpenAI by entering your API token, which you can generate from the OpenAI API page. Once you have your token, paste it into the connection settings of Pabbly Connect. For the AI model, select GPT-6 and enter the necessary prompt details for caption generation.
  • Enter your content idea, target audience, and content tone.
  • Map these details dynamically using the previous step’s data.
  • Click “Save and Send Test Request” to generate the response.
After a few seconds, you will receive a response containing the generated caption and hashtags. This data will be used in your Google Sheets, demonstrating how Pabbly Connect facilitates dynamic data handling.
4. Updating Google Sheets with Generated Captions
Now that you have generated captions, the next step is to update your Google Sheets with this information. Go back to your Pabbly Connect workflow and click on “Add Action” again. Select “Google Sheets” and choose the event “Update Row”.
Connect your Google account and select the appropriate spreadsheet. Map the row index and the generated caption and hashtags to the respective columns. This ensures that the right data fills in the correct cells in your Google Sheets.
  • Select the spreadsheet and specify the row that needs updating.
  • Map the caption and hashtags from the OpenAI response.
  • Click “Save and Send Test Request” to update the row.
After this step, your Google Sheets will reflect the newly generated captions and hashtags, showcasing the power of Pabbly Connect in automating your workflow.
5. Automating the Entire Process
To ensure the automation runs seamlessly, you can enable the “Send on Event” option in the Pabbly Connect WBx add-on. This ensures that whenever new data is entered into the specified column of your Google Sheets, Pabbly Connect will automatically trigger the workflow to generate captions.
With this setup, you no longer need to manually initiate the process. As soon as data is added, the entire automation will run, generating captions and hashtags in real-time. This is a powerful example of how Pabbly Connect can streamline your business operations.
In this tutorial, we explored how to build AI automations using Pabbly Connect and GPT-6. By integrating Google Sheets and automating the caption generation process, you can enhance your workflow efficiency significantly. Start using Pabbly Connect today to streamline your business operations.
