To get started with automating your LinkedIn posts, first, you need to access Pabbly Connect. Open a new tab in your browser and navigate to pabbl.com/connect. This will take you to the landing page of Pabbly Connect.
On this page, you can click on the “Sign up for free” button to begin your free trial of Pabbly Connect. If you enjoy the features, consider subscribing using the discount code RIT YT for a special offer.
Once you’ve signed up, log into your Pabbly Connect dashboard. Click on the “Create Workflow” button to start building your automation. This setup will enable you to automate daily LinkedIn posts.
To set up the automation, follow these steps:
  • Click on the “Add Trigger” button.
  • Choose “Schedule” as your trigger event.
  • Set the schedule for every day at 12:00 PM.
After saving the trigger, your workflow is now scheduled to run daily at the specified time, preparing for the next steps in automation.
3. Integrating OpenAI with Pabbly Connect
Next, you will integrate OpenAI to generate post content. Click on “Add New Action Step” and select OpenAI from the list. Choose “Chat GPT” as the event and click on “Connect”.
Follow these steps to connect OpenAI:
  • Click on “Add New Connection” to get your OpenAI API key.
  • Create a new secret key in your OpenAI account.
  • Copy the key and paste it into Pabbly Connect.
Once connected, select your AI model (e.g., GPT 5.2) and input the prompt to generate LinkedIn post content tailored to your business needs. Click “Save and Send Test Request” to see the generated content.
4. Posting Generated Content to LinkedIn via Pabbly Connect
Now that you have the content generated by OpenAI, it’s time to post it on LinkedIn. Click on “Add New Action Step” and search for LinkedIn. Choose “Share Simple Text” as the event and connect your LinkedIn account to Pabbly Connect.
To finalize the LinkedIn post, follow these steps:
  • Log into your LinkedIn account when prompted.
  • Map the content generated by OpenAI into the LinkedIn post.
  • Set the visibility options for your post.
After saving this step, your LinkedIn post will be automatically generated and published every day at 12 PM, thanks to the seamless integration with Pabbly Connect.
5. Exploring More Automations with Pabbly Connect
With Pabbly Connect, you can explore numerous other automations beyond LinkedIn. This platform allows you to connect various applications like Facebook, Instagram, Twitter, and more for your social media needs.
Here are some additional features you can explore:
  • Automate posts across multiple platforms.
  • Schedule regular updates on Discord and Slack.
  • Use AI tools for content generation across various channels.
By leveraging the capabilities of Pabbly Connect, you can enhance your online presence and streamline your social media management effectively.
In this tutorial, we explored how to automate LinkedIn posts using Pabbly Connect and OpenAI. This integration allows you to effortlessly create and schedule content, enhancing your social media strategy.
