To start using Pabbly Connect for your WhatsApp integration, first visit the Pabbly website and sign up for an account. Once logged in, navigate to the Pabbly Connect dashboard. Here, you can easily create workflows that automate responses for your WhatsApp messages.
After signing up, you will find yourself on the Pabbly Connect homepage. From here, you can access the Pabbly Chartflow feature, which enables you to build chatbots without any coding skills. This user-friendly interface allows you to set up automated responses for various triggers, making it essential for your WhatsApp chatbot.
2. Creating Your First Chatbot Flow with Pabbly Connect
Once you’re in the Pabbly Chartflow builder, click on the ‘+ Add Flow’ button to start creating your chatbot. You will be prompted to name your flow; for this example, you can name it “WhatsApp Chatbot for Broadcast Hub.” This step is crucial as it sets the foundation for your automated responses.
  • Click on the ‘+ Add Flow’ button to create a new flow.
  • Name your flow appropriately for easy identification.
  • Select the trigger event that will activate your chatbot.
For the trigger event, select ‘Keywords’ as your method. This means your bot will respond when users send specific keywords like “hi” or “hello.” After adding these keywords, your bot is ready to respond to user inquiries instantly.
3. Setting Up Automated Responses with Pabbly Connect
After setting the trigger keywords, the next step is to configure your automated responses. You will need to add a welcome message that the bot will send when a keyword is detected. This message can include an image and text to enhance user interaction.
To do this, click on the ‘Add Content’ button and select the type as ‘Text’. Enter your welcome message, such as “Welcome to your official broadcasting hub! How can I assist you today?” Additionally, create quick reply buttons like “Request Air Time,” “Upcoming Events,” and “Talk to Team” for user engagement.
  • Add a welcome message with text and an image.
  • Create quick reply buttons for user options.
  • Ensure the bot can handle multiple user inputs effectively.
These responses will make your chatbot more interactive and user-friendly, allowing for a smoother communication experience on WhatsApp.
4. Collecting User Input through Pabbly Connect
In this section, you will configure your bot to collect user input effectively. When a user selects the “Request Air Time” button, the bot should prompt them to provide their event name, description, full name, and contact number.
To set this up, add a question for each input you want to collect. For instance, after asking for the event name, follow up with requests for a short description and the user’s contact information. Make sure to set the appropriate contact custom fields for each input to personalize the responses.
  • Add questions for event name, description, full name, and contact number.
  • Use contact custom fields to personalize user responses.
  • Ensure validation messages guide users for correct input format.
This setup ensures that your bot collects all necessary information seamlessly, enhancing the user experience and automating your workflow efficiently.
5. Finalizing Your Chatbot Flow with Pabbly Connect
After configuring all the necessary responses and user inputs, it’s time to finalize your chatbot flow. Ensure that all components are connected properly and that the flow is active. Click the “Save” button to update your flow and make it operational.
Your final chatbot will now respond in real-time to users on WhatsApp, providing them with the information they need without any manual input from you. This automation is made possible through the capabilities of Pabbly Connect, ensuring a smooth user experience.
  • Review all connections in the flow to ensure they are correct.
  • Click the “Save” button to activate your chatbot.
  • Test the chatbot by sending keywords to see the automated responses.
This final step ensures your WhatsApp chatbot is fully functional, providing automated replies that enhance customer interaction and streamline your communication process.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect to create an automated chatbot. By following these steps, you can enhance user engagement and streamline communication for your business.
