To begin integrating WhatsApp with your chatbot, first access Pabbly Connect. Open a new tab and search for Pabbly’s official site. If you’re a new user, click on the “Sign Up Free” option to get started. Existing users should simply sign in to their accounts.
After logging in, you will see all Pabbly applications. Click on the “Access Now” button under Pabbly Chartflow to navigate to the dashboard. Here, you can manage your WhatsApp numbers and set up the integration process.
2. Creating Your WhatsApp Chatbot Flow
Once you are on the Pabbly Chartflow dashboard, it’s time to create your WhatsApp chatbot. Click on the “Add Flow” button to start building your flow. Make sure to name your flow appropriately, such as “WhatsApp Chatbot for Pharmacy”.
  • Select the trigger event for your flow.
  • Choose the template option to create a flow based on a pre-designed template.
  • Select the pharmacy welcome message template.
After selecting the template, you can customize it as needed. Ensure the flow is active by toggling the active button. Save your progress before proceeding to the next steps.
3. Customizing Your Chatbot Flow with Pabbly Connect
To effectively customize your chatbot, navigate to the flows feature. Here, you can utilize the drag-and-drop builder to add various actions. Start by adding a button that prompts users to order medicine or upload a prescription.
For each button, you can define what happens next. For example, when a user clicks on “Order Medicine”, the bot should ask for their full name. This interaction can be set up by selecting the “Ask Question” action and defining the question and expected response format.
  • Define the question to ask users for their full name.
  • Set the response format to text.
  • Link the response to the next action in the flow.
Make sure to save your flow regularly to avoid losing any progress. This customization process is crucial for ensuring that your chatbot engages effectively with users.
4. Testing Your WhatsApp Chatbot with Pabbly Connect
After setting up your flow, it’s time to test your WhatsApp chatbot. Navigate to the inbox feature within Pabbly Connect to send the template message to yourself. Choose the pharmacy welcome template and click send to initiate the conversation.
Once you receive the message, interact with the chatbot by clicking the buttons. For example, if you click on “Order Medicine”, the bot should prompt you for your full name. Enter your details and see how the bot responds, ensuring it provides a seamless experience.
  • Verify that the bot asks for the correct information.
  • Check that the responses are personalized based on user input.
  • Ensure that all buttons function as intended.
Testing is essential to ensure your WhatsApp chatbot operates smoothly and effectively engages users. Make any necessary adjustments based on your testing results.
5. Conclusion
Integrating a WhatsApp chatbot using Pabbly Connect can significantly enhance your business’s customer interaction. By following the steps outlined in this tutorial, you can create a fully functional chatbot that automates your sales process. Ensure to test thoroughly and customize your flow for the best user experience.
