1. Setting Up Pabbly Connect for WhatsApp Broadcast
To build a WhatsApp Broadcast System that generates sales, you first need to access Pabbly Connect. This platform serves as the backbone for integrating various applications, including Pabbly Chat Flow and CSV files.
Start by logging into your Pabbly Connect account. Once logged in, navigate to the Pabbly Chat Flow section to set up your broadcast campaign. This integration allows you to manage contacts and send messages effectively.
2. Creating Your Broadcast Campaign with Pabbly Chat Flow
Once you’re in Pabbly Chat Flow, you can create a broadcast campaign. Click on the “Add Broadcast” button to initiate the process. This feature allows you to reach multiple users simultaneously.
- Choose the type of broadcast campaign.
- Enter a name for your broadcast.
- Select your audience from existing contacts or upload a CSV file.
This step is crucial for targeting your audience effectively. You can upload a CSV file containing customer details or select a predefined contact list.
3. Optimizing Your Audience in Pabbly Connect
After selecting your audience, you can optimize it further within Pabbly Connect. This involves filtering out contacts that you do not want to receive the broadcast messages.
- Exclude specific contacts from the broadcast.
- Skip contacts who have messaged you in the last 24 hours.
By refining your audience, you ensure that your messages reach the right people at the right time, maximizing engagement.
4. Crafting Your Message for the Broadcast
The next step involves crafting your message for the broadcast. Within Pabbly Connect, you have the option to use either a template message or a standard message.
If you opt for a template message, ensure it is pre-approved by WhatsApp. This allows you to initiate conversations without waiting for a customer message. For testing, enter a sample contact and send a test message to verify its appearance.
5. Scheduling and Sending Your Broadcast
After crafting your message, you can schedule it for a specific time or send it immediately. In Pabbly Connect, select the scheduling option and specify the date and time for sending your broadcast.
Additionally, you can enable automatic retries for any contacts that fail to receive the message. This ensures that your broadcast reaches as many people as possible without manual intervention.
In this tutorial, we explored how to build a WhatsApp Broadcast System that generates sales using Pabbly Connect. By integrating Pabbly Chat Flow and CSV files, you can effectively reach your audience and promote your products.
