To start using Pabbly Connect for integrating WhatsApp AI, you first need to create an account. Visit the Pabbly website and complete the sign-up process. Once you are logged in, you will be directed to the Pabbly Connect dashboard.
After logging in, you can easily navigate through various features. Pabbly Connect serves as the central hub for managing integrations between different applications, making it straightforward to set up your WhatsApp AI assistant.
2. Creating Your WhatsApp AI Assistant with Pabbly Connect
Once you are on the Pabbly Connect dashboard, locate the option for creating a new assistant. Click on the ‘Add Assistant’ button to initiate the setup process. This is where you will define how your AI assistant will operate.
  • Select the instruction type as AI agent.
  • Set the temperature for response creativity.
  • Choose the model provider as OpenAI.
After making these selections, you will need to paste your OpenAI API key into the designated field. This key allows Pabbly Connect to communicate with OpenAI, enabling your assistant to generate responses based on the provided instructions.
3. Configuring Assistant Settings in Pabbly Connect
In this step, you will customize your assistant settings within Pabbly Connect. This includes adding any necessary headers or footers and defining stop keywords that will halt the conversation when triggered.
Additionally, you can specify the number of retry attempts for your assistant to respond to user queries. This ensures that users receive timely responses, even if the initial attempt fails. The fallback message is also crucial, as it provides a standard response in case of technical issues.
  • Enable the toggle for header/footer customization.
  • Set the retry attempts to a maximum of 10.
  • Define fallback messages for error handling.
Once you have configured these settings, your assistant will be better equipped to handle various user interactions seamlessly through Pabbly Connect.
4. Uploading Your Knowledge Base for the Assistant
The knowledge base is essential for your assistant to provide accurate responses. Using Pabbly Connect, you can upload a knowledge base file that contains all relevant business information. This file serves as the brain of your assistant.
To create this file, you can use Google Docs and ensure it’s saved in either PDF or TXT format. Remember, the file size should not exceed 90 MB, and if it’s a PDF with images, it should be limited to 10 pages.
After preparing the knowledge base file, simply click on the option to add a new file and upload it through Pabbly Connect. This step is crucial for ensuring your assistant provides specific and accurate replies based on your business’s unique offerings.
5. Finalizing Your Assistant Setup in Pabbly Connect
After successfully uploading your knowledge base, it’s time to finalize your assistant’s setup. You can customize the assistant’s interface by entering a heading and adjusting its design elements to match your brand.
Once you are satisfied with the design, enable the toggle to activate your assistant. Finally, click on the ‘Save Assistant’ button to complete the setup process. This ensures that your WhatsApp AI agent is now live and ready to assist your customers.
With everything set up, you can manage your assistant’s inbox settings in Pabbly Connect. Make sure to enable the necessary toggles and select the contact list for your assistant to operate effectively.
In this tutorial, we covered how to integrate WhatsApp AI using Pabbly Connect, outlining each step from account creation to final setup. By following these instructions, you can automate your business communications effectively, ensuring customer queries are answered promptly.
