To start integrating WhatsApp with Pabbly Connect, first, you need to access the Pabbly Connect dashboard. This platform allows you to automate workflows between different applications, including WhatsApp. Simply visit the Pabbly website and log in to your account.
Once logged in, navigate to the Pabbly Connect section. Here, you can create a new workflow that connects WhatsApp with your desired applications. This will enable you to automate responses and streamline communication with your clients.
2. Creating a WhatsApp Assistant with Pabbly Connect
Creating a WhatsApp assistant is straightforward with Pabbly Connect. Start by clicking on the “Create Assistant” button in the dashboard. You will be prompted to enter a name for your assistant, such as “Dental Clinic Assistant.” This name will help you identify the assistant later.
  • Click on “Add Assistant” after naming it.
  • Choose the type of instructions for the assistant, like customer support.
  • Set the temperature for responses to control the creativity level.
After setting these parameters, you can proceed to customize the instructions for your assistant. This ensures that it responds accurately to customer queries, enhancing user experience.
3. Connecting Your WhatsApp Number to Pabbly Connect
To enable your WhatsApp assistant, you must connect your WhatsApp number to Pabbly Connect. This can be done by clicking on the “Add WhatsApp Number” option. If you are using a WhatsApp Business account, you can easily scan a QR code to link your number.
Once your number is connected, you can access various features available in Pabbly Connect. This integration allows you to automate responses based on the queries received through WhatsApp, improving efficiency in handling customer inquiries.
4. Setting Up Knowledge Source for Your Assistant
Setting up a knowledge source is crucial for your WhatsApp assistant to provide accurate responses. You need to upload a PDF or TXT file containing all the necessary information about your business, such as services, prices, and policies. This file will serve as the reference for the assistant.
  • Create a detailed knowledge source document.
  • Upload the document in the Pabbly Connect interface.
  • Ensure the assistant can access this information for answering queries.
After uploading the knowledge source, your assistant will be equipped to handle inquiries effectively, providing instant replies based on the information contained in the document.
5. Finalizing and Assigning Your WhatsApp Assistant
Once you have configured your assistant and uploaded the knowledge source, the next step is to finalize its settings. You can customize the initial messages and branding elements to ensure it aligns with your business identity.
After finalizing the settings, you can assign the assistant to specific contacts or enable it for all incoming messages. This flexibility allows you to manage responses efficiently. By clicking on the “Assign Assistant” button, you can select the contacts who will receive automated replies.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect to create a responsive assistant for your business. Utilizing Pabbly Connect streamlines communication, allowing you to automate replies effectively. This integration enhances customer engagement and improves operational efficiency.
