To automate daily gaming tips on Discord, start by accessing Pabbly Connect. If you are a new user, open a new tab and search for pabbl.com/connect to reach the landing page.
Once on the page, click on the ‘Sign Up for Free’ button located in the top right corner. You will receive 100 free tasks each month to explore Pabbly Connect and create your automation workflows.
After signing up, log into your dashboard and click on the ‘Create Workflow’ option. Select ‘Create Using AI’ to initiate the process for your automation.
Next, name your workflow as “Daily Post on Discord” and click the ‘Create’ button. This will open a dialog where you can specify your query for posting daily messages on Discord.
  • Enter the time you want to post the message.
  • Specify the content of the message, which should be a gaming tip.
  • Provide your time zone for accurate scheduling.
After entering these details, send your query. Pabbly Connect will confirm your request and ask for your Discord webhook URL.
3. Setting Up Discord Webhook URL
To integrate Discord with Pabbly Connect, you need to set up a webhook. Open your Discord server, navigate to the channel where you want to post the gaming tips, and access the channel settings.
In the settings, find the ‘Integrations’ tab and create a new webhook. Name this webhook (e.g., “New Post”) and copy the generated URL.
  • Go to your Discord server and select the relevant channel.
  • Click on ‘Edit Channel’ and navigate to ‘Integrations’.
  • Create a webhook and copy the URL.
Paste this webhook URL into Pabbly Connect to finalize the integration. This step is crucial for automating your Discord messages.
4. Testing Your Workflow in Pabbly Connect
With the webhook URL set, you can now test your workflow in Pabbly Connect. After sending the webhook URL, wait for a few seconds as the system activates your workflow.
You will receive a confirmation message in your Discord channel indicating that the gaming tip bot is being set up. This confirms that your automation is functioning correctly.
To ensure everything works as expected, click on the ‘Test My Workflow’ button. This will generate a gaming tip and post it to your Discord channel for verification.
5. Finalizing Your Automation with Pabbly Connect
Once your workflow is tested successfully, you will see a summary of the scheduled posts in Pabbly Connect. Confirm the activation of your schedule by typing ‘yes’ when prompted.
After activation, your workflow will automatically post gaming tips to your Discord channel at the scheduled time. You can monitor and manage this workflow directly from your Pabbly Connect dashboard.
With everything in place, you can now enjoy automated daily gaming tips without needing to post manually. This integration showcases the power of Pabbly Connect in streamlining your processes.
In this tutorial, we’ve detailed how to automate daily gaming tips on Discord using Pabbly Connect. By following these steps, you can easily set up and manage your automated posts, ensuring consistent engagement with your community.
