1. Accessing Pabbly Connect for Your AI WhatsApp Chatbot
To build an AI WhatsApp Chatbot for hotels, the first step is accessing Pabbly Connect. Start by visiting the Pabbly website and signing up or logging in to your account. This platform acts as the central hub for integrating various applications and automating workflows.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find options to create new workflows that integrate the necessary applications for your chatbot setup.
2. Setting Up Pabi Chartflow in Pabbly Connect
Next, you will set up Pabbly Chartflow as part of your integration process. Go to the Pabi Chartflow interface by accessing the appropriate section in Pabbly Connect. This tool is essential for managing your WhatsApp communications.
Follow these steps to set up Pabi Chartflow:
  • Log in to Pabi Chartflow.
  • Connect your WhatsApp number within the platform.
  • Access the AI assistant feature to create your chatbot.
Once you complete these steps, you will have Pabi Chartflow ready for your AI chatbot integration.
3. Creating Your AI Assistant with Pabbly Connect
Now, it’s time to create your AI assistant using Pabbly Connect. Click on the option to add a new assistant. You will need to provide a name and select the instruction type from the drop-down menu. Choose options like AI agent or customer support agent based on your needs.
After selecting the instruction type, set the AI configuration. Key settings include:
  • Temperature: Adjust to control the creativity of responses.
  • AI Provider: Choose OpenAI for your AI responses.
  • API Key: Input your OpenAI API key to connect the AI.
These configurations enable your assistant to respond accurately to customer inquiries.
4. Configuring AI Assistant Settings in Pabbly Connect
With your assistant created, the next step involves configuring its settings through Pabbly Connect. This includes setting a header message, footer message, and defining stop keywords that trigger human intervention.
To finalize settings, consider the following options:
  • Header Message: Customize the greeting displayed to users.
  • Stop Keywords: Enter specific words that will stop the AI from responding.
  • Fallback Message: Set a default message for unrecognized queries.
>These configurations ensure your AI assistant can handle customer queries effectively while allowing for human oversight when necessary.
5. Assigning Your AI Assistant to WhatsApp Chats
Finally, you will assign your AI assistant to WhatsApp chats using Pabbly Connect. To do this, access the inbox settings in your Pabi Chartflow dashboard. Here, you can enable the AI assistant to automatically reply to customer messages.
Follow these steps to assign your assistant:
  • Scroll to AI Auto Reply Settings in the inbox settings.
  • Select the contact list for which the assistant will be active.
  • Save your changes to activate the assistant.
>After completing these steps, your AI assistant will be fully operational and ready to manage customer interactions on WhatsApp.
In this tutorial, we explored how to build an AI WhatsApp Chatbot for hotels using Pabbly Connect. By following the detailed steps provided, you can automate customer interactions effectively. This setup enhances customer service while minimizing manual effort.
