To start automating your lead management, first access Pabbly Connect. Create a free account at the Pabbly Connect website, where you will receive 100 free tasks to explore the platform. This allows you to test the integration capabilities of Pabbly Connect effectively.
After signing up, you will land on the Pabbly Connect dashboard. Here, you can manage all your automation workflows. To create a new workflow, click on the ‘+ Create Workflow’ button. You have three options: create from scratch, create using AI, or create using quick builder. For this tutorial, select the quick builder option.
2. Creating a Workflow with Pabbly Connect
Once you select the quick builder, the Connect Studio will appear. You’ll need to enter a prompt describing what you want to achieve. For instance, you can type ‘Send Typeform leads to Zoho CRM’. This prompt helps Pabbly Connect generate a suitable workflow for you.
  • Select the Typeform trigger as ‘New Entry’
  • Choose Zoho CRM as the action application
  • Set the action to ‘Create Contact’
After making these selections, Pabbly Connect will create the workflow and prompt you for approval. Click on the ‘Approve and Create’ button to finalize the setup.
3. Connecting Typeform with Pabbly Connect
Next, to connect Typeform with Pabbly Connect, click on the Typeform application in your workflow. Then, press the ‘Connect’ button. If you have an existing connection, you can use that; otherwise, select the option to add a new connection.
Once prompted, grant Pabbly Connect permission by clicking the ‘Accept’ button. After connecting, select the specific Typeform you want to use, such as your webinar registration form. You can customize this form as needed.
4. Mapping Data from Typeform to Zoho CRM
After setting up Typeform, it’s time to map the data to Zoho CRM. Click on the Zoho CRM application in your workflow and select the ‘Connect’ button. Again, if you need a new connection, choose that option and provide your Zoho domain.
Now, you will perform the mapping of the data received from Typeform. Mapping is crucial as it allows dynamic data transfer. For instance, map the first name, last name, email address, and phone number fields accordingly. Once completed, click on the ‘Save and Send Request’ button to test the integration.
  • Map the first name to the corresponding field
  • Map the email address field
  • Map the phone number field
After mapping, you should receive a positive response confirming that the new contact has been created in Zoho CRM.
5. Finalizing Your Pabbly Connect Workflow
To complete your automation, ensure to enable the toggle for your workflow. If this toggle is not enabled, your workflow will not function. This step is crucial for ensuring that every new Typeform submission is automatically transferred to Zoho CRM.
After enabling the toggle, your workflow is now fully operational! You can test it by submitting a test lead through Typeform. Pabbly Connect will handle the rest, automatically transferring the data to your CRM without any manual intervention.
If you encounter any issues or have questions, feel free to comment below. This is just one of many integrations you can create using Pabbly Connect. Explore the possibilities and automate your processes effectively!
This tutorial demonstrated how to use Pabbly Connect to automate lead management by integrating Typeform with Zoho CRM. This seamless integration saves time and ensures that no lead is missed, enhancing your business efficiency.
