To begin integrating WhatsApp with Salesforce, first access Pabbly Connect by visiting the Pabbly website. Simply type ‘pabbly.com’ in your browser’s address bar. Once there, sign in using your existing account or create a new one.
If you are a new user, you can sign up for free and explore Pabbly’s features. Existing users should click on the “Sign In” option located at the top right corner. After signing in, navigate to the Pabbly Connect dashboard to start creating your workflow.
In the Pabbly Connect dashboard, you can create a new workflow by clicking on the plus icon. Name your workflow something descriptive, like “Automatically Create CRM Contacts from WhatsApp Leads”. Select the appropriate folder for organization, such as “WhatsApp Automations”.
  • Click on the plus icon to create a new workflow.
  • Choose a folder for better organization.
Once created, you will see a box prompting you to enter your trigger application. Remember, the trigger is the event that starts your workflow. Here, select “WhatsApp Cloud API” as your trigger application.
3. Setting Up the Trigger for WhatsApp
In this step, you need to select the trigger event. Choose “Message Notification” and click on connect. A webhook URL will be generated, which acts as a bridge between your WhatsApp and Pabbly Connect.
To set this up, go to Meta for Developers by typing ‘developers.facebook.com’. After logging in, navigate to “My Apps” and select the app you created. Under the WhatsApp section, you will find the production setup where you need to enter the webhook URL and a verified token.
  • Paste the webhook URL in the appropriate field.
  • Enter the verified token as per the instructions.
  • Save the settings to finalize the webhook configuration.
After saving, scroll down to subscribe to messages and test the setup. This ensures that your connection between WhatsApp and Pabbly Connect is working correctly.
4. Adding Action Step to Create Contacts in Salesforce
After successfully setting up the trigger, the next step is to add an action. Click on “Add New Action Step” and search for “Salesforce”. In the action event, select “Create Contact” and click on connect.
If you have an existing connection, you can save it; otherwise, create a new connection by clicking on “Add New Connection”. Grant permission to Pabbly Connect to access your Salesforce account.
  • Select Salesforce as the action application.
  • Choose the action event to create a contact.
  • Connect your Salesforce account to Pabbly Connect.
Now, you will need to map the data received from WhatsApp to Salesforce fields. Instead of entering data manually, use the mapping feature in Pabbly Connect for dynamic data entry.
Once you have mapped the necessary fields, click on “Save and Send Test Request” to check if the integration works. A successful response will confirm that a new contact has been created in Salesforce based on the WhatsApp message received.
To ensure everything is functioning as intended, check your Salesforce contacts. You should see the newly created contact with the details from the WhatsApp message. This confirms that your integration using Pabbly Connect is successful.
By following these steps, you can automate the process of creating leads in Salesforce from WhatsApp messages seamlessly. This integration enhances efficiency and ensures that no lead is missed.
In this tutorial, we demonstrated how to integrate WhatsApp with Salesforce using Pabbly Connect. This automation allows for efficient lead management directly from WhatsApp messages, enhancing your CRM capabilities.
