To begin automating WhatsApp messages, access Pabbly Connect and create an account if you haven’t already. After logging in, navigate to the dashboard where you can set up various integrations.
Once in the dashboard, look for the option to create a new workflow. This is where you will define how your WhatsApp AI assistant will interact with customers. Pabbly Connect provides a seamless platform to link your WhatsApp with various applications.
2. Creating Your AI Assistant with Pabbly Chatbot
Within Pabbly Connect, go to the Pabbly Chatbot section. Here, you can create an AI assistant that will handle customer queries automatically. Click on the “Add AI Assistant” button to start the process.
  • Select a descriptive name for your AI assistant.
  • Choose the type of instructions your assistant will use, such as AI agent.
  • Set the temperature for AI responses, adjusting creativity levels.
After setting up these initial parameters, you will need to configure the AI model provider, which is OpenAI in this case. By doing this, Pabbly Connect allows you to create a highly responsive AI assistant tailored to your business needs.
3. Configuring AI Assistant Settings in Pabbly Connect
Next, configure the settings for your AI assistant in Pabbly Connect. This includes entering your OpenAI API key, which is essential for the assistant to function properly. Ensure that you have a paid OpenAI account to generate this key.
Additionally, you can set retry attempts, fallback messages, and stop keywords that will help manage conversations effectively. These settings ensure that your AI assistant can handle various scenarios during customer interactions.
  • Enter your API key obtained from OpenAI.
  • Customize retry attempts to define how many times the AI will try to respond.
  • Set a fallback message for technical errors.
These configurations allow Pabbly Connect to provide a robust AI assistant that can respond accurately and efficiently to customer inquiries.
4. Uploading Knowledge Base for Your AI Assistant
To enhance the AI assistant’s responses, you need to upload a knowledge base file. This file contains all necessary information about your business, which the AI will reference when answering customer queries. Use Pabbly Connect to easily upload this file.
Ensure the knowledge base is comprehensive, containing product details, policies, and FAQs. You can create this file using Google Docs or any text editor, ensuring it is under the specified size limits.
  • Upload a PDF or text file with business information.
  • Ensure the file size is less than 90 MB for optimal performance.
  • Include all relevant information to help the AI respond accurately.
By integrating this knowledge base into Pabbly Connect, your AI assistant will be better equipped to handle customer inquiries effectively.
5. Activating Your AI Assistant in Pabbly Connect
Finally, activate your AI assistant by enabling it in the settings of Pabbly Connect. This will allow your assistant to start receiving and responding to customer messages on WhatsApp.
Ensure that you have selected the appropriate contact list for your AI assistant and saved the configurations. This step is crucial for ensuring that your AI assistant is operational and ready to assist customers.
Once activated, your AI assistant can handle customer queries 24/7, providing consistent and accurate responses. This automation not only saves time but also enhances customer satisfaction.
In this tutorial, we explored how to automate WhatsApp messages using Pabbly Connect to create an AI assistant. By following the steps outlined, you can enhance your customer interactions and streamline your business processes effectively.
