1. Accessing Pabbly Connect for WhatsApp Automation
To automate WhatsApp messages, you first need to access Pabbly Connect. Open your browser and navigate to the Pabbly Connect homepage. If you’re a new user, click on ‘Sign Up for Free’ to create an account or ‘Sign In’ if you already have one.
Once logged in, you will see all Pabbly applications. Click on ‘Access Now’ for Pabbly Chatflow, which is essential for sending WhatsApp messages. This integration is crucial as it connects your WhatsApp account with your customer data stored in Google Sheets.
2. Setting Up WhatsApp Broadcasts Using Pabbly Connect
After accessing Pabbly Chatflow, you will need to set up a WhatsApp broadcast. This is done by creating a message template that will be sent to multiple contacts. In Pabbly Chatflow, navigate to the ‘Templates’ section to create or view your existing templates.
  • Click on ‘Add Template’ to create a new message.
  • Ensure your template is approved by Meta for use.
  • You can attach images or other media to your template.
Once your template is ready, head to the ‘Broadcast’ section in Pabbly Chatflow to start your WhatsApp messaging campaign. Here, you can manage your broadcasts and view statistics.
3. Importing Contacts from Google Sheets into Pabbly Connect
To send messages, you must import your customer contacts into Pabbly Connect. If your contacts are stored in Google Sheets, download them as a CSV file. This step is vital as it allows you to manage your audience effectively.
In the Broadcast section, select the option to upload a CSV file. This will add your contacts to Pabbly Chatflow. You can also choose to select existing contact lists directly from Pabbly Connect. Make sure to refine your audience by excluding contacts who should not receive the messages.
4. Sending WhatsApp Messages with Pabbly Connect
With your contacts imported, you are ready to send WhatsApp messages. In the Broadcast section, select your created template and choose the audience you want to reach. This process is streamlined through Pabbly Connect, making it easier to manage large-scale communications.
  • Choose ‘Pre-approved Template’ or ‘Regular Message’ based on your needs.
  • Test your broadcast by sending a message to your own WhatsApp number first.
  • Schedule the broadcast or send it immediately based on your preference.
Once you’ve confirmed everything, click ‘Add Broadcast’ to initiate the message sending process. You can track the delivery status directly within Pabbly Connect.
5. Monitoring Broadcast Results in Pabbly Connect
After sending your WhatsApp messages, monitoring the results is crucial. Pabbly Connect provides detailed statistics on sent, delivered, and read messages. This feature allows you to analyze the effectiveness of your broadcasts.
In the Broadcast section, you can view data such as sent, delivered, and ignored messages. This information helps you refine future campaigns. Additionally, if any messages fail, you can easily resend them through Pabbly Connect.
In this tutorial, we explored how to automate WhatsApp messages using Pabbly Connect. By following these steps, you can efficiently send bulk messages to your customers and enhance your communication strategy. Pabbly Connect is essential for managing these integrations seamlessly.
