To begin automating social media posts, access Pabbly Connect by visiting the dashboard. If you are a new user, simply search for pabbl.com/connect in your browser to reach the landing page.
Once on the page, click on the “Sign Up for Free” button located in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks each month, making it perfect for testing your automation setup.
Once logged into Pabbly Connect, click on the “Create Workflow” button. You will see options to create using AI. Select this option to proceed to the Agentic AI dashboard.
  • Click on “Create Workflow”.
  • Select “Create Using AI”.
  • Enter a name for your workflow.
After naming your workflow, you will see a prompt welcoming you to Agentic AI. Here, you can describe your automation needs to build your workflow without any coding skills.
3. Setting Up Facebook Posting Automation
To automate Facebook posts, start by instructing Agentic AI. Type “Post daily on Facebook at 1 PM” and send this message. The AI will respond with questions to refine your request.
  • Specify your Facebook page name.
  • Indicate the type of content (e.g., fashion tips).
Once you provide this information, the AI will analyze it and confirm the automation setup, asking for necessary permissions such as the Facebook page access token.
4. Obtaining Facebook Access Token
To obtain the required access token, follow the instructions provided by Agentic AI. First, create a Facebook app by visiting the Facebook Developer portal.
After creating the app, you will need to add specific permissions for posting on your Facebook page. This includes:
  • Manage and publish your pages.
  • Read engagement metrics.
Once permissions are set, you can generate the access token from the Graph API Explorer and copy it for use in your automation workflow with Pabbly Connect.
5. Testing Your Social Media Automation
After setting everything up, it’s time to test your workflow. Click on the “Test Workflow” button in Pabbly Connect. This will allow you to ensure that all steps are functioning correctly.
Once the test is complete, check your Facebook page for the new post generated by the automation. If successful, you will see the fashion tip along with an image posted at the scheduled time.
This setup can also be replicated for other platforms like Instagram, allowing you to automate posts across multiple social media channels seamlessly using Pabbly Connect.
By following this guide, you can effectively automate social media posts using Pabbly Connect and Agentic AI. This integration simplifies the process, allowing you to maintain consistent social media engagement effortlessly.
