To begin the integration process with Pabbly Connect, first, search for Pabbly Connect at pabyt.com/connect in your browser. This will take you to the homepage of Pabbly Connect.
On the homepage, you will find options to either sign in or sign up. If you are a new user, click on “Sign up for free” to receive 100 free tasks each month. Existing users can simply sign in. After signing in, access Pabbly Connect by clicking on “Access Now” to reach the dashboard.
Once you are on the Pabbly Connect dashboard, you need to create a new workflow for the integration. Select the “Create using Quick Builder” option to initiate the process quickly.
Now, you will be prompted to describe your automation. Enter the prompt: “When a payment is received on Razer Pay, add in Google Sheets.” This will allow Pabbly Connect to set up the necessary triggers and actions.
  • Select “Payment Captured” as the trigger from Razer Pay.
  • Choose “Add a New Row” for Google Sheets as the action.
After confirming your selections, click on “Approve and Create” to finalize the workflow setup. You will receive a workflow link that confirms the creation of your workflow.
3. Setting Up the Trigger with Razer Pay
Now that your workflow is created, the next step is to set up the trigger. Pabbly Connect provides a webhook URL that you will use to connect Razer Pay.
Copy the webhook URL and log into your Razer Pay account. Navigate to the “Developers” section, then click on “Webhooks”. Here, you can create a new webhook by clicking the “Add” button. Paste the copied webhook URL and select “Payment Captured” as the active event.
  • Leave the secret field blank.
  • Click on “Create Webhook” to finalize the setup.
You will see the webhook is set up successfully, and Pabbly Connect will be waiting for the webhook response to confirm the integration.
4. Testing the Integration with a Payment
To test the integration, you need to make a test payment through Razer Pay. Ensure that your payment page is in test mode. Fill in the required fields with dummy data and select a payment method.
After completing the test payment, return to Pabbly Connect. You should see a successful response indicating that the payment details have been captured. This confirms that the trigger is working correctly.
  • Enter dummy details such as email, phone number, and product information.
  • Select “Success” as the payment status for the test.
Once you receive the successful response in Pabbly Connect, it indicates that the trigger is fully functional and ready for automation.
5. Mapping Data to Google Sheets
After confirming that the trigger works, the next step is to set up the Google Sheets action in Pabbly Connect. Click on “Sign in with Google” to connect your Google account securely.
Once connected, select the spreadsheet where you want to log the payment details. Map the fields such as customer name, email, phone number, payment amount, and order ID from the Razer Pay response to the corresponding fields in Google Sheets.
  • Use the mapping feature to insert dynamic data from the trigger response.
  • Ensure that the payment amount is formatted correctly using Pabbly’s number formatter.
After mapping all required fields, click on “Save and Send Test Request” to verify that the data is correctly added to Google Sheets. A successful response will confirm that your automation is complete.
In this tutorial, we demonstrated how to integrate Razer Pay with Google Sheets using Pabbly Connect. This automation allows you to streamline payment data entry, saving you time and effort. By following these steps, you can easily set up similar workflows for your business needs.
