To automate Facebook posts using Pabbly Connect, first, access the platform by visiting pabbly.com/connect. Here, you can sign up for a free trial, allowing you to create up to 100 posts.
Once you have signed up, log in to your Pabbly Connect dashboard. From there, click on the “Create Workflow” button to initiate your automation process. This will set the stage for connecting various applications seamlessly.
In the Pabbly Connect dashboard, click on “Create Using Quick Builder” and select “Start Fresh”. You will be prompted to paste a prompt that says, “Schedule daily Facebook posts using Gemini to get images and captions and post both on Facebook.” This is the starting point for your workflow.
- Select the “Schedule Workflow” option.
- Choose the first event as “Generate Content” and the second as “Generate Image” using Gemini.
- Select your Facebook Pages for posting.
After setting these parameters, approve and create your workflow. This will enable the automation to run at the scheduled time daily, streamlining your posting process.
3. Setting the Schedule for Facebook Posts
With the workflow created in Pabbly Connect, the next step is to set the schedule for your posts. You can specify how often you want the workflow to run. For daily posts, select “Everyday” and set the time to 1:00 PM.
Once you click the “Save” button, the schedule will be activated. This ensures that your posts are automatically generated and published at the specified time without any manual intervention.
4. Connecting Google AI to Generate Content
To generate captions for your Facebook posts, you need to connect Google AI through Pabbly Connect. Click on “Connect” and then “Add a New Connection” to link your Google AI account.
- Open Google AI Studio and navigate to “Get API” section.
- Create your API key and copy it back to Pabbly Connect.
- Enter your prompt for generating captions in the designated field.
After entering the prompt, you can test the connection to ensure everything is working correctly. This integration allows for automated caption generation based on your specifications.
5. Posting Generated Content to Facebook
Finally, to post the generated content to Facebook, return to Pabbly Connect and connect your Facebook account. Click on “Add a New Connection” and select “Connect with Facebook Pages” to authorize the connection.
Choose the Facebook page where you want to post and map the generated image URL and caption to the respective fields. Click on “Save and Send Test Request” to finalize the process. A positive response confirms that your post has been successfully created on Facebook.
Using Pabbly Connect, you can effortlessly automate Facebook posts with Google AI. This streamlined process not only saves time but also enhances your social media management, allowing you to focus on other important tasks.
