To begin integrating Facebook Lead Ads with Fresh Sales CRM, you first need to access Pabbly Connect. This powerful tool allows you to automate workflows without any coding skills. Simply sign up for a free account to get started.
Once logged in, you will receive 100 free tasks each month, enabling you to create and test your automation. This means you can follow along with the setup in this tutorial and see how Pabbly Connect streamlines the process.
The first step in your integration is to set up the trigger in Pabbly Connect. For this, select “Facebook Lead Ads” as your trigger application and choose the event “New Lead”. This event will activate the workflow whenever a new lead is generated from your Facebook ads.
  • Select “Facebook Lead Ads” as the trigger application.
  • Choose “New Lead” as the trigger event.
  • Click on “Connect” to link your Facebook account.
After connecting, select your business page and the lead form you want to use. This setup ensures that every new lead from Facebook is captured in your Pabbly Connect workflow, ready to be processed further.
3. Generating Test Leads for Verification
To ensure that your integration is functioning correctly, you will need to generate a test lead. This can be done using Meta’s lead ads testing tool. First, delete any existing test leads to avoid duplication.
  • Use Meta’s lead ads testing tool to create a new lead.
  • Fill in the lead details, including name, email, and phone number.
  • Submit the lead and check if it appears in Pabbly Connect.
Once the lead is generated, you should see it captured in the trigger section of Pabbly Connect. This confirms that your integration is working as intended, allowing real leads to be processed automatically.
4. Setting Up the Action to Create Contacts
Now that your trigger is set up, it’s time to configure the action in Pabbly Connect. Select “Fresh Sales CRM” as the action application and choose the event “Create Contact”. This action will automatically add new leads as contacts in your CRM.
You’ll need to provide the API key and domain for your Fresh Sales account. To find these, log into your Fresh Sales account, navigate to the profile section, and access the API settings. Copy the required information and paste it into Pabbly Connect.
5. Mapping Data for New Contacts in Fresh Sales
With your action set up, the next step is to map the data from your Facebook lead to the contact fields in Fresh Sales CRM. This is crucial for ensuring that all lead information is accurately transferred.
  • Map the email address by using the correct prefix (home, work, or office).
  • Map the first name and last name from the lead data.
  • Set the source as “Social Media” and the lifecycle stage as “Lead”.
After mapping all necessary fields, click on the “Send Test Request” button. If successful, you will receive a confirmation that the contact has been created in your Fresh Sales account. This completes the integration process using Pabbly Connect.
In this tutorial, we explored how to automate the integration of Facebook Lead Ads with Fresh Sales CRM using Pabbly Connect. By following these steps, you can streamline your lead management process and ensure no leads are missed.
