1. Introduction to Pabbly Connect for WhatsApp Marketing
Pabbly Connect is essential for small businesses looking to maximize their marketing efforts through WhatsApp. This platform allows seamless integration between various applications, making it easier to reach potential customers effectively. By using Pabbly Connect, businesses can automate their marketing campaigns and manage customer interactions efficiently.
To get started, access Pabbly Connect and create your account. Once you’re logged in, you’ll be ready to set up your WhatsApp marketing campaign. This tutorial will guide you through the step-by-step process of using Pabbly Connect to reach your audience.
2. Setting Up Your Broadcast Campaign with Pabbly Chat Flow
To create a broadcast campaign, navigate to the Pabbly Chat Flow section within Pabbly Connect. Click on the “Add Broadcast” button to initiate the process. Here, you’ll need to select the type of broadcast campaign you want to create. For this example, we’ll choose a “Broadcast Campaign”.
  • Click on “Add Broadcast”.
  • Select “Broadcast Campaign”.
  • Name your campaign, e.g., “Catering Services Promotion”.
After naming your campaign, you need to select the audience. Pabbly Connect offers options to use an existing contact list or upload a CSV file. For this tutorial, we will choose the “Existing Contact List” option and select our “Leads List”.
3. Optimizing Your Audience with Pabbly Connect
Next, you can refine your audience in Pabbly Connect. This step is optional but recommended for targeting specific customers. If you want to exclude certain contacts from receiving the broadcast, you can select those from the dropdown menu.
Additionally, you can enable the option to skip contacts that have messaged you in the last 24 hours. This ensures that your messages are not repetitive for those who have recently interacted with you.
  • Exclude specific contacts from the broadcast.
  • Enable the option to skip recent contacts.
Once your audience is optimized, you are ready to move on to the message type selection, which is crucial for your campaign’s success.
4. Crafting Your Message in Pabbly Chat Flow
In this step, you will define the type of message you want to send via WhatsApp. Pabbly Connect allows you to choose between a pre-approved template message or a regular message. If you want to initiate a new conversation, select the template message option.
For this example, we will choose the “Royal Feast Catering” template. You can also add an image to make your message more engaging. Click on the “Add New Image” button to upload an image from your gallery.
  • Select “Royal Feast Catering” template.
  • Upload an image to enhance your message.
After crafting your message, you can test the broadcast by sending a trial message to yourself. This ensures everything appears as intended before the actual broadcast.
5. Scheduling and Sending Your Broadcast via Pabbly Connect
Once you have tested your message, you can schedule your broadcast. Pabbly Connect allows you to send messages immediately or schedule them for a later time. For example, you can set the broadcast to be sent on October 25th at 10:00 AM.
Additionally, Pabbly Connect features an automatic retry option for contacts that fail to receive the message. You can set the number of retries and the waiting period between attempts, ensuring your message reaches everyone effectively.
  • Schedule your broadcast for a specific date and time.
  • Enable automatic retries for failed messages.
After setting everything up, click on the “Create Broadcast” button to finalize your campaign. With Pabbly Connect, you can streamline your WhatsApp marketing efforts and significantly boost your customer engagement.
Using Pabbly Connect for WhatsApp marketing allows small businesses to efficiently reach hundreds of potential customers. By following these steps, you can create effective broadcast campaigns that drive engagement and increase orders.
