1. Setting Up Pabbly Connect for Lead Qualification
To start using Pabbly Connect, you need to access the dashboard after signing up. Pabbly Connect is an automation platform that allows you to integrate various applications seamlessly. After logging in, click on the “Create Workflow” button to begin your automation process.
You will have three options to create a workflow: from scratch, using AI, or quick builder. For this tutorial, select the option to create from scratch. Name your workflow as “How SaaS Company Qualifies Website Leads Using Open AI” and click on the connect button to proceed.
2. Triggering Webhook in Pabbly Connect
The next step involves setting up the trigger for your workflow using Pabbly Connect. Here, you will select “Webhook by Pabbly” as your trigger application. This allows your website form to communicate with Pabbly Connect whenever a new lead is submitted.
After selecting Webhook, choose the event “Catch Webhook”. Pabbly Connect will provide you with a Webhook URL. Copy this URL and paste it into your website’s code to link the form submission to the Pabbly Connect workflow.
  • Select “Webhook by Pabbly” as the trigger application.
  • Choose the event “Catch Webhook”.
  • Copy the provided Webhook URL and paste it into your website’s code.
After saving the changes, submit a test inquiry through your website form to ensure that the Webhook is working correctly. This will confirm that Pabbly Connect is successfully receiving data from your website.
3. Integrating OpenAI with Pabbly Connect
Next, you need to set up OpenAI to analyze the leads captured through your website using Pabbly Connect. Select OpenAI as your action application and choose the event “Generate Response Using Text Input”. This action allows OpenAI to evaluate the lead’s buying intent based on the information submitted.
To connect OpenAI, you will need an API key. Navigate to your OpenAI API keys page to create a new secret key. Copy this key and paste it into Pabbly Connect when prompted. After this, select the OpenAI model you wish to use, such as GPT-4 Omni.
  • Choose OpenAI as the action application.
  • Select the event “Generate Response Using Text Input”.
  • Paste your OpenAI API key and select the model.
Mapping the lead information from the Webhook response to OpenAI is crucial. This ensures that OpenAI receives the correct details to analyze the lead’s requirements and buying intent effectively.
4. Routing Leads Based on Priority with Pabbly Connect
Once OpenAI has analyzed the lead, the next step is to route the leads based on their priority using Pabbly Connect. You will set up a router that creates multiple paths for high and low priority leads. This allows your workflow to intelligently decide how to manage incoming inquiries.
For high priority leads, set a filter to check if the OpenAI response contains the word “high”. If true, the workflow will proceed to notify your sales team via Slack. For low priority leads, you will set another filter that checks for the word “low” and routes these leads to Google Sheets for future follow-up.
  • Create a router in Pabbly Connect to manage lead priority.
  • Set filters for high and low priority leads based on OpenAI’s response.
  • Notify the sales team via Slack for high priority leads.
This routing mechanism ensures that your sales team only receives notifications for leads that require immediate attention, while lower priority inquiries are stored for later nurturing.
5. Saving Low Priority Leads to Google Sheets via Pabbly Connect
Finally, to manage low priority leads efficiently, you will integrate Google Sheets with Pabbly Connect. This allows all low priority leads to be automatically stored in a designated spreadsheet for future follow-up. Select Google Sheets as your action application and choose the event “Add New Row”.
After connecting your Google Sheets account, select the appropriate spreadsheet where you want to store the leads. Map the required fields from the Webhook response to the respective columns in your Google Sheet.
  • Select Google Sheets as the action application.
  • Choose the event “Add New Row” to store leads.
  • Map fields from the Webhook response to your Google Sheets.
This integration ensures that all low priority leads are organized and easily accessible for future nurturing, enhancing your lead management process.
In this tutorial, we explored how to automate lead qualification using Pabbly Connect, OpenAI, and Google Sheets. By following these steps, you can efficiently manage leads and improve your sales process. Implement this workflow to enhance your business operations today.
