To begin integrating WhatsApp with AI assistants, you need to set up Pabbly Connect. Start by signing up at the Pabbly website. Once registered, you will receive 100 free credits each month to explore the software. This is perfect for testing the integration process.
After signing in, navigate to the Pabbly Connect dashboard. Here, you can select the application you want to work with, which in this case is WhatsApp. Follow the prompts to connect your WhatsApp number to the Pabbly Connect platform.
2. Creating an AI Assistant Using Pabbly Connect
Once your WhatsApp number is connected, the next step is to create an AI assistant. This is done through the assistant feature in Pabbly Connect. Click on the ‘Create New Assistant’ button and provide a descriptive name for your assistant. This name will help identify the assistant in your dashboard.
  • Select the instruction type as AI agent.
  • Set the temperature for AI responses to control creativity.
  • Choose OpenAI as the model provider and select the AI model variant.
These steps will define how your AI assistant behaves when responding to user queries. Make sure to configure these settings accurately to ensure optimal performance of your AI assistant.
3. Configuring API Keys and Assistant Settings
To fully utilize your AI assistant, you need to configure the API keys. In Pabbly Connect, navigate to the API settings and paste your OpenAI API key. To obtain this key, go to your OpenAI API keys page and create a new secret key.
After pasting the API key, click the connect button. This will link your assistant with the OpenAI model, allowing it to generate responses. Adjust the assistant settings, including retry attempts and fallback messages, to enhance user interaction.
4. Uploading Your Knowledge Base in Pabbly Connect
Next, upload your knowledge base file to train the AI assistant. This file should contain all relevant business information, ensuring that the AI provides accurate and context-specific answers. In Pabbly Connect, click on the ‘Upload Knowledge Base’ option and select your prepared file.
  • Ensure your knowledge base is in .txt or PDF format.
  • File size should be less than 90 MB.
  • If using PDF, limit images to 10 pages.
This step is crucial as it allows the assistant to provide tailored responses based on your business’s specific offerings and guidelines.
5. Finalizing Your AI Assistant’s Design
After uploading the knowledge base, you can customize the design of your AI assistant. In Pabbly Connect, modify the appearance by changing themes, colors, and shapes. This ensures that the assistant aligns with your brand’s identity.
Once satisfied with the design, enable the toggle to activate your assistant and click on the save button. This will finalize your setup, making your AI assistant ready to interact with customers via WhatsApp.
In this tutorial, you have learned how to integrate WhatsApp with AI assistants using Pabbly Connect. This powerful tool allows you to provide instant product recommendations to your customers, enhancing their shopping experience and driving sales.
