1. Accessing Pabbly Connect for Recruitment Broadcasts
To start using Pabbly Connect, visit the official website and sign up for an account. Once registered, you can access the dashboard where you can manage all your integrations.
After logging in, select the Pabbly Chat Flow application. This tool is essential for automating WhatsApp messages, making it perfect for recruitment agencies looking to reach multiple candidates efficiently.
2. Creating a Broadcast Campaign with Pabbly Connect
Creating a broadcast campaign in Pabbly Connect is straightforward. First, navigate to the broadcast feature on the left-hand menu. This feature allows you to send a single WhatsApp message to multiple contacts simultaneously.
- Click on the “+ Add Broadcast” button.
- Choose the broadcast type as “Broadcast Campaign”.
- Name your broadcast (e.g., “Job Openings Alert”).
Next, select the contact list you want to use for your broadcast. This is where Pabbly Connect simplifies the process by allowing you to import contacts in bulk from a CSV file.
3. Importing Contacts into Pabbly Connect
To import contacts into Pabbly Connect, navigate to the contacts feature. You can add contacts manually or upload a CSV file for bulk import. The CSV format is simple and allows for easy data management.
- Prepare a Google Sheet or Excel file with the first name, last name, and phone number of your candidates.
- Download your file in CSV format.
- Upload the CSV file in the Pabbly Chat Flow interface.
Once uploaded, you can create a contact list and select it for your broadcast campaign. This feature of Pabbly Connect allows you to manage large volumes of contacts efficiently.
4. Setting Up Message Templates in Pabbly Connect
With your contacts in place, the next step is to set up a message template within Pabbly Connect. This template will be sent to all selected candidates, ensuring personalized communication.
To create a template, go to the templates feature in Pabbly Chat Flow and click on “+ Add Template”. Here, you can define your message content, including placeholders for candidate names.
- Select the message type as “Pre-approved Template” to comply with WhatsApp guidelines.
- Add the message content, including a placeholder (e.g., “$name”) for personalization.
- Upload any media, like videos, to enhance your message.
After creating the template, you can test it by sending a message to ensure everything works as expected. This step is crucial to validate that Pabbly Connect is set up correctly for your broadcast.
5. Scheduling Your Broadcast with Pabbly Connect
Once your message template is ready, you can schedule your broadcast through Pabbly Connect. This feature allows you to choose a specific time for your messages to be sent, ensuring timely communication with candidates.
To schedule your broadcast, select the scheduling option in the broadcast setup. You can specify the date and time for when you want the messages to be sent out.
- Choose the date and time for the broadcast.
- Confirm by clicking on the “+ Add Broadcast” button.
By utilizing the scheduling feature in Pabbly Connect, you can ensure that your candidates receive timely updates about job opportunities, enhancing their experience and engagement.
In conclusion, using Pabbly Connect allows recruitment agencies to efficiently send personalized job opportunities through WhatsApp. By following the steps outlined in this tutorial, you can easily set up a broadcast campaign, import contacts, create message templates, and schedule broadcasts. This not only saves time but also improves candidate engagement significantly.
