1. Accessing Pabbly Connect for Lead Automation
To start automating lead capture for real estate businesses, you need to access Pabbly Connect. Open a new tab and search for ‘pab.com connect’. This will lead you to the Pabbly Connect landing page, where you can sign up for a free account or log in if you are an existing user.
If you are a new user, click on the ‘Sign Up for Free’ button to get 100 free tasks each month. For existing users, simply click on the ‘Sign In’ button. Pabbly Connect is a powerful tool that allows you to integrate various applications seamlessly.
2. Setting Up Facebook Leads in Pabbly Connect
After logging into Pabbly Connect, you can create a workflow to capture Facebook leads. Start by clicking on ‘Create Workflow’. Enter a name like “Connect Facebook Leads to Google Sheets” and hit ‘Create’. This sets the stage for your automation.
- Click on ‘Add New Connection’ and select ‘Connect with Facebook Leads’.
- Log in to your Facebook account when prompted.
- Choose your Facebook page where your lead generation form is located.
Once connected, select the lead generation form you want to use. This allows Pabbly Connect to capture new leads automatically as they come in from Facebook.
3. Capturing Leads in Google Sheets
Next, you will set up the action in Pabbly Connect to store the captured leads in Google Sheets. Select ‘Add New Connection’ and choose ‘Google Sheets’. Log in to your Google account and allow access to Pabbly Connect.
After connecting, select the specific Google Sheet where you want to store the lead data. Map the fields from the Facebook lead capture to the corresponding columns in your Google Sheet. This ensures that every new lead is logged accurately.
- Map the lead’s full name to the corresponding column.
- Map the email address and contact number as well.
- Ensure all relevant details are mapped correctly to automate data entry.
Once mapping is complete, click on ‘Save and Send Test Request’ to ensure everything is working correctly. Refresh your Google Sheet to see the new lead entries.
4. Sending WhatsApp Messages via Pabbly Connect
To enhance engagement, you can set up WhatsApp messaging through Pabbly Connect. After capturing leads, click on the plus button in your workflow to add another action. Choose ‘WhatsApp API’ as your messaging service.
Connect your WhatsApp account and set up the message template you want to send to new leads. This feature allows you to follow up with leads immediately after they fill out your form, increasing your chances of conversion.
- Customize your message to include lead details like name and property type.
- Ensure the message is friendly and prompts further engagement.
By integrating WhatsApp with Pabbly Connect, you can automate your communication strategy and keep potential clients informed and engaged.
5. Conclusion
In this tutorial, we explored how to use Pabbly Connect to automate the lead capture process for real estate businesses. By integrating Facebook leads with Google Sheets and WhatsApp, you can streamline your operations and enhance customer engagement.
Utilizing Pabbly Connect not only saves time but also ensures that no lead goes unnoticed. Automate your lead management today to maximize your business potential.
