1. Accessing Pabbly Connect for Shipment Alerts
To begin, accessing Pabbly Connect is crucial for logistics teams wanting instant shipment alerts. First, visit pabbly.com/connect and create a free account. This allows you to explore the software with 100 free tasks monthly, perfect for testing.
After signing up, log in to your account. You will find all Pabbly applications. Click on Pabbly Connect to access the dashboard where you can create and manage automation workflows. Start by clicking the “Create Workflow” button.
2. Creating an Integration Workflow with Pabbly Connect
Creating a workflow in Pabbly Connect is straightforward. Select the quick builder option to initiate the integration. You’ll be prompted to provide a single line prompt, such as “Connect Pabbly Chatbot with Slack.” This will help Pabbly Connect analyze your request.
- Choose the Pabbly Chatbot trigger: New Message Received.
- Select the Slack action: Send Channel Message.
- Approve and create the workflow.
Upon approval, your workflow will be created successfully. This integration allows logistics teams to receive shipment details from WhatsApp directly into their Slack channel without manual intervention.
3. Setting Up Pabbly Chatbot Integration
In this step, you will set up Pabbly Connect to connect with Pabbly Chatbot. Click on the Pabbly Chatbot application in your workflow. This action will provide you with a webhook URL and the necessary steps to connect your Pabbly Chatbot account.
Copy the webhook URL and navigate to your Chatbot flow builder. Here, design your flow by adding welcome messages and buttons. Ensure you include contact custom fields like sender name, receiver name, and shipment details. After creating the flow, add an API request button to connect your chatbot with Pabbly Connect.
4. Configuring API Request in Pabbly Chatbot
To configure the API request in your chatbot, select the request mode as POST and paste the copied webhook URL. You will send data to Pabbly Connect using parameters. Select each contact custom field you’ve created in the workflow.
- Sender Name
- Receiver Name
- Shipment Type
- Contact Number
- Pickup Address
- Delivery Address
After mapping the fields, click on the test button to ensure the connection works. If successful, you will see a confirmation message, indicating that your setup is complete.
5. Finalizing the Slack Connection in Pabbly Connect
Now, it’s time to connect Slack to Pabbly Connect. Click on the Slack application in your workflow, then select the connect button. Choose to add a new connection and enter the token type as bot. This allows Pabbly Connect to send messages to your Slack channel.
Once connected, select the channel where you want to receive shipment alerts. In the message field, dynamically map the responses from Pabbly Chatbot to include all relevant shipment details. This ensures that your logistics team receives accurate information in real-time.
Finally, save your workflow and enable the toggle to activate the automation. This ensures that the integration works seamlessly, providing instant shipment alerts to your logistics teams.
Using Pabbly Connect, logistics teams can automate shipment alerts efficiently. This tutorial outlined how to integrate Pabbly Chatbot with Slack for instant notifications, ensuring a streamlined communication process.
