To create a WhatsApp assistant for your logistics business, start by accessing Pabbly Connect. Visit the official website and log in to your account. If you are new, sign up for free to receive 100 credits monthly, allowing you to test the features of Pabbly Connect.
After logging in, navigate to the dashboard where you can explore various features. This platform is designed to automate tasks and integrate multiple applications seamlessly, specifically for logistics queries via WhatsApp.
2. Creating Your WhatsApp Assistant with Pabbly Connect
Once you’re on the dashboard of Pabbly Connect, go to the “Assistant” section and click on “Add Assistant”. Name your assistant according to your logistics business, for example, “Swift Cargo Logistics”. This naming helps in identifying the assistant later.
Next, you will see several sections to complete. Ensure you fill in the following:
  • Choose the instruction type (select “AI Agent”)
  • Set the temperature (0.5 for balanced replies)
  • Select OpenAI as the AI model
Completing these sections helps your assistant respond accurately to queries. The setup process is straightforward, especially with the guidance of Pabbly Connect.
3. Configuring Knowledge Source in Pabbly Connect
To enhance your assistant’s responses, you need to set up a knowledge base. This is crucial for your logistics operations. Create a document outlining your business policies and services, and upload it in the knowledge source section of Pabbly Connect.
After uploading, ensure your knowledge base is visible in the section. This allows the assistant to frame responses based on the information provided. A well-structured knowledge base is key to effective query resolution.
4. Styling and Customizing Your Assistant with Pabbly Connect
In this section, you can customize the appearance of your assistant. Add your brand name, logo, and adjust the colors to align with your business identity. This is done in the “Assistant Interface” section of Pabbly Connect.
Also, configure the user’s first message and styling options. This enhances user interaction and ensures your assistant reflects your brand’s personality. Once done, toggle the settings and save your configurations.
5. Testing and Deploying Your WhatsApp Assistant with Pabbly Connect
After setting up your assistant, it’s time to test its functionality. You can simulate a conversation by asking common questions related to logistics. The assistant should respond accurately, indicating a successful setup through Pabbly Connect.
To deploy the assistant on your website, copy the provided script from Pabbly Connect and paste it into your website’s code. This integration allows your assistant to interact with customers directly on your site.
In this tutorial, we explored how to create a WhatsApp assistant for your logistics business using Pabbly Connect. By following these steps, you can automate query resolution and enhance customer service effectively.
