1. Accessing Pabbly Connect to Create Your WhatsApp Assistant
To create a WhatsApp assistant using Pabbly Connect, first, visit the official Pabbly Chartflow page. This platform allows you to automate WhatsApp communications efficiently. If you’re new, click on “Sign Up Free” to get started with 100 free credits monthly.
If you already have an account, simply click on “Sign In”. After logging in, access Pabbly Chartflow by clicking on the “Access Now” button. This will redirect you to the dashboard, where you can manage your WhatsApp numbers.
2. Creating Your WhatsApp Assistant in Pabbly Connect
Creating your assistant begins with selecting the assistant feature in Pabbly Connect. Click on the “Add Assistant” button to start. You need to give your assistant a descriptive name, such as “Logistics Inquiry Assistant”. This name should reflect the assistant’s purpose.
  • Click on the plus sign to add a new assistant.
  • Enter a descriptive name for your assistant.
  • Select the instruction type as AI agent.
After naming your assistant, customize its behavior by selecting the instruction type. This defines how the assistant will respond to users. You can also adjust the temperature setting, which controls the creativity of responses.
3. Integrating OpenAI with Pabbly Connect
To enhance your assistant’s capabilities, integrate OpenAI through Pabbly Connect. You will need to obtain an API key from the OpenAI platform. Click on “Create New Secret Key” to generate your API key.
Once you have the API key, paste it into the designated field in Pabbly Connect. After saving, your OpenAI integration will be complete, allowing your assistant to provide intelligent responses based on user queries.
4. Setting Up Knowledge Base for Your Assistant
Next, you need to upload a knowledge base file in Pabbly Connect. This file contains essential information that your assistant will use to answer inquiries accurately. Ensure the file is in .txt or PDF format and less than 90 MB in size.
  • Create a knowledge base file with FAQs and service details.
  • Upload the file through the “Add New File” option.
  • Ensure the file is properly formatted for best results.
After uploading, customize the assistant’s interface to reflect your brand. You can modify headings, subheadings, and initial messages to cater to your logistics business needs.
5. Finalizing Your WhatsApp Assistant in Pabbly Connect
To finalize your assistant, enable the toggle to make it active and click on the “Save Assistant” button in Pabbly Connect. Once saved, your assistant will be ready to handle customer inquiries on WhatsApp.
Set up inbox settings to manage contacts and ensure that your assistant is accessible to all users. Enable AI auto-reply settings and select the contact list for your assistant.
In this tutorial, you learned how to create a WhatsApp assistant for logistics using Pabbly Connect. By following the steps outlined, you can automate customer support and improve response times. This setup allows your business to operate efficiently, providing 24/7 support without additional costs.
