To begin your journey with Pabbly Chatflow, navigate to the official website by entering www.pabbly.com/chatflow in your browser. This platform allows you to create a WhatsApp chatbot seamlessly.
Once on the Pabbly Chatflow page, you will need to sign in or sign up for a free account. Existing users can click on “Sign In” while new users should select “Sign Up for Free” to receive 100 free tasks monthly. This is a great way to explore the features available in Pabbly Chatflow.
2. Connecting Your WhatsApp Number to Pabbly Chatflow
After logging into Pabbly Chatflow, the next step is to connect your WhatsApp number. Click on the “Add WhatsApp Number” button on the dashboard. This will redirect you to the connection options.
- Choose “WhatsApp Connect” as the preferred method.
- Alternatively, you can use a manual token for connection.
Once your WhatsApp number is connected, you will see your WhatsApp number displayed on the dashboard. This is crucial for automating your conversations using Pabbly Chatflow.
3. Creating Your AI Agent in Pabbly Chatflow
To set up your AI agent, navigate to the “AI Assistant” feature within Pabbly Chatflow. Click on the option to create a new assistant and name it (e.g., “Legal Ease Associates”). This is where you will define how your chatbot interacts with users.
In the AI configuration settings, set the instruction type to “AI Agent” and adjust the temperature for creativity in responses. A value of 0.7 is recommended for a balance between creativity and focus. Make sure to select the OpenAI model (GPT-5 Mini) for optimal performance.
4. Configuring AI Settings and Knowledge Base
In this step, you will configure various settings for your AI assistant. Start by entering a header and footer message that will be displayed to users. You can also set up stop keywords to halt responses when needed. This ensures users have control over the conversation.
- Enter a fallback message for unresolved queries.
- Upload a detailed knowledge base file that contains all necessary information about your services.
Once these settings are configured, save your AI assistant. This will allow Pabbly Chatflow to utilize the uploaded knowledge base to respond to user queries effectively.
5. Assigning Your AI Assistant to Contacts
Finally, to ensure your AI assistant responds to user messages, you must assign it to specific contacts or groups. Navigate to the “Inbox” settings and choose the AI assistant you created. This step is crucial for automating responses in your WhatsApp conversations.
You can select a particular list of contacts or assign the assistant to all contacts. After making your selections, save the rules. This will allow Pabbly Chatflow to automatically manage conversations based on the defined settings.
By following this tutorial, you can effectively create a WhatsApp chatbot using Pabbly Chatflow. This integration automates responses, enhancing customer interaction and streamlining your business operations. Start utilizing Pabbly Chatflow today for a more efficient communication channel.
