To integrate Shopify with Slack, start by accessing Pabbly Connect. This platform allows seamless automation between various applications.
Visit the Pabbly Connect homepage and sign up for a free trial. After signing in, navigate to the workflow builder to begin the integration process.
2. Setting Up Shopify in Pabbly Connect
In this section, we will set up Shopify as the trigger for our automation using Pabbly Connect. Click on the “Add Trigger” button and select Shopify.
Choose Shopify V2 and select the event as “New Order”. Click on the “Connect” button to establish a connection with your Shopify account. You will be provided with a URL; copy this for later use.
  • Click on the “Add Trigger” button.
  • Select Shopify V2.
  • Choose “New Order” as the event.
  • Click “Connect” and copy the provided URL.
Next, navigate to your Shopify store settings and paste the copied URL into the webhook settings to complete the integration.
3. Configuring the Shopify Webhook
Now we will configure the webhook in Shopify to send order notifications to Pabbly Connect. In your Shopify admin, go to Settings, then Notifications, and find the Webhooks section.
Click on “Create Webhook” and select “Order Creation” as the event. Paste the URL you copied earlier and set the format to JSON. Click “Save” to finalize the webhook setup.
  • Go to Shopify Settings.
  • Select Notifications and find Webhooks.
  • Click on “Create Webhook”.
  • Choose “Order Creation” and paste the URL.
  • Set the format to JSON and click “Save”.
After saving, your Shopify store is now configured to send order notifications to Pabbly Connect.
4. Sending Notifications to Slack via Pabbly Connect
With Shopify set up, it’s time to send notifications to Slack using Pabbly Connect. In your workflow, click on “Add Action” and select Slack as the action application.
Choose the action event as “Send Channel Message”. Connect your Slack account by entering the required token and granting permissions. Select the channel where you want to send notifications and customize your message.
  • Click “Add Action” and select Slack.
  • Choose “Send Channel Message” as the action event.
  • Connect your Slack account and enter the token.
  • Select the channel for notifications.
  • Customize your message and save the action.
Now, whenever a new order is created in Shopify, a notification will be sent to your specified Slack channel through Pabbly Connect.
5. Testing the Integration of Shopify and Slack
To ensure everything is working correctly, perform a test purchase in your Shopify store. After completing the purchase, check your Slack channel for the notification.
If the setup is correct, you should see a message with the order details in Slack. This confirms that Pabbly Connect has successfully integrated Shopify with Slack.
In case of any issues, revisit the settings in Pabbly Connect and Shopify to ensure everything was configured correctly.
In this tutorial, we demonstrated how to integrate Shopify with Slack using Pabbly Connect. By following these steps, you can automate notifications for new orders and enhance team communication.
Utilizing Pabbly Connect allows for seamless integration between applications, making your workflow more efficient. Start automating your processes today!
