To start using Pabbly Connect, open your browser and go to chatflow.pabbly.com. This is where you can create your account and begin your WhatsApp automation journey.
Once registered, you will need to link your WhatsApp number to your Pabbly Connect account. This step is crucial for sending messages through the platform. Follow the prompts to complete this setup.
2. Setting Up Your Broadcast in Pabbly Connect
After linking your WhatsApp number, navigate to the left sidebar and select “Broadcast”. This will take you to the WhatsApp broadcast page where you can create your messaging campaign.
- Choose the type of broadcast as “broadcast campaign”.
- Name your broadcast, for example, “new serum launch”.
- Select your audience from existing contact lists or upload a CSV file with customer details.
Using Pabbly Connect, you can easily manage your audience and ensure that your messages reach the right people. You can filter contacts to exclude those you don’t want to message.
3. Crafting Your Message with Pabbly Connect
Next, you need to decide on the type of message you want to send. You can either write a regular message or choose to send a template message. If using a template, make sure it is approved by Meta to avoid any issues.
To create a template, select “Template List” from the sidebar. Here, you can add new templates that include dynamic placeholders for personalization, such as the customer’s name.
- Add images and buttons to enhance engagement.
- Preview your message to ensure everything looks correct.
Utilizing Pabbly Connect for crafting messages allows for quick adjustments and effective communication strategies tailored to your audience’s preferences.
4. Scheduling Your Broadcast with Pabbly Connect
Once your message is ready, you can choose to send it immediately or schedule it for a later time. If you opt to schedule, select the date and time for your broadcast.
Additionally, Pabbly Connect offers an automatic retry feature for any contacts that fail to receive the message. This ensures your broadcast is sent successfully without manual intervention.
5. Monitoring Broadcast Results through Pabbly Connect
After your broadcast is sent, you can view the statistics by clicking on the “View Statistics” button. This feature allows you to track the performance of your messaging campaign.
Using Pabbly Connect for monitoring results gives you insights into customer engagement and helps refine future campaigns for better results.
In this tutorial, we explored how to use Pabbly Connect to integrate Pabbly, Pabbly Chatbot, and Broadcast effectively. By following these steps, you can enhance your customer communication and engagement.
