1. Introduction to Pabbly Connect for LinkedIn Automation
Pabbly Connect is a powerful integration tool that allows you to automate your LinkedIn posts with ease. In this tutorial, we will explore how you can schedule 30 days of LinkedIn posts using Pabbly Connect in just minutes. This automation not only saves time but also ensures consistency and quality in your content.
By using Pabbly Connect, you can connect various applications seamlessly. This tutorial will guide you through setting up your automated LinkedIn posting workflow, so you can focus on other important tasks while your posts go live daily.
2. Accessing Pabbly Connect and Setting Up Your Workflow
To begin, you need to open Pabbly Connect and navigate to the workflow builder. Click on the ‘Add Trigger’ button to start your automation process. For the trigger application, select ‘Schedule by Pabbly’. This is crucial as it will determine when your LinkedIn posts will be published.
  • Select the event as ‘Schedule Workflow’.
  • Choose how often you want your workflow to run; select ‘Every Day’.
  • Set the time for posting, for example, ‘2 PM’.
Once you have configured these settings, click on the ‘Save’ button. Now, your workflow is set to trigger every day at the specified time using Pabbly Connect.
3. Integrating AI for Content Generation
Next, you need to add an AI agent to generate your LinkedIn post content. Click on ‘Add New Action Step’ to specify the action application. You can use various AI tools such as OpenAI or Gemini. In this case, we will select OpenAI, which is widely used for generating content.
For the event, choose ‘Chat GPT’ and connect it with Pabbly Connect. You will need to provide an API token to link OpenAI with your workflow. To obtain this token, visit the OpenAI API key page, create a new key, and copy it into your workflow.
4. Finalizing LinkedIn Post Settings with Pabbly Connect
After connecting OpenAI, you will need to select the model you want to use, such as GPT-5. For the prompt, customize your content according to your business needs. This customization is important to ensure that the generated posts are relevant and engaging.
  • Enter a tailored prompt for your business.
  • Click on ‘Save and Send Test Request’ to generate the content.
  • Ensure the generated content does not repeat topics or hooks.
Once you receive the generated content, you can proceed to share it on LinkedIn using Pabbly Connect. This ensures that your posts are unique and engaging every day.
5. Sharing Your Generated Content on LinkedIn
To post the generated content on LinkedIn, add another action step in your Pabbly Connect workflow. Select LinkedIn as the application and choose the event as ‘Share Simple Text’. Connect your LinkedIn account to Pabbly Connect to facilitate this integration.
Make sure your LinkedIn account is logged in. If not, you will be prompted to log in. After logging in, select the author and map the content generated by OpenAI. This mapping feature allows you to insert dynamic data from previous steps easily.
Finally, click on ‘Save and Send Test Request’ to share your post on LinkedIn. You can verify by checking your LinkedIn profile to see if the post has been successfully shared. With Pabbly Connect, you now have an automated system that posts daily without manual intervention.
Using Pabbly Connect, you can efficiently automate your LinkedIn posts, scheduling 30 days of content in just minutes. This process enhances your online presence and engagement without the hassle of daily posting.
