1. Setting Up Pabbly Connect for Facebook Posts Using AI
To create viral Facebook posts using AI, the first step is to set up Pabbly Connect. Start by signing into your Pabbly Connect account. This platform is essential for integrating your Instagram and YouTube accounts, allowing seamless automation for your posts.
Once logged in, navigate to the “Connect” section and click on “Add New Connection”. Here, you will set up the integration to capture your Instagram posts automatically. Make sure your Instagram account is linked to a Facebook account for this process to work smoothly.
2. Connecting Instagram to Pabbly Connect
Next, you need to connect your Instagram account through Pabbly Connect. Click on the “Connect with Instagram for Business” button. This allows Pabbly Connect to access your Instagram posts, which is crucial for automating the posting process.
During this step, ensure that your Instagram account is linked to a Facebook account. This linkage is necessary as Pabbly Connect requires Facebook permissions to access Instagram data. Follow these steps to complete the connection:
- Click on “Connect with Instagram for Business”.
- Select your Instagram account from the dropdown menu.
- Click “Save and Send Test Request” to confirm the connection.
This will allow Pabbly Connect to capture your Instagram posts automatically.
3. Capturing Instagram Posts in Pabbly Connect
After connecting Instagram, the next step in Pabbly Connect is to capture your posts. Create a new reel on Instagram, and make sure to include a caption. This reel will be automatically captured by Pabbly Connect once it’s posted.
To test this, create a new reel and click on “Save and Send Test Request” in Pabbly Connect. You will see the media URL of your newly posted reel captured in the response. Ensure that your Instagram account is set to check for new posts every 10 minutes, allowing Pabbly Connect to pull in new content efficiently.
4. Filtering Reels for YouTube Upload
Now that you have captured your Instagram posts, the next step in Pabbly Connect is to filter these posts to ensure only reels are uploaded to YouTube. This is important because you only want video content to be shared on your YouTube channel.
To set this up, add a filter step in Pabbly Connect that checks if the product type is a reel. If the condition is true, the workflow will proceed to upload the video to YouTube. Here’s how to configure the filter:
- Add a filter step in your workflow.
- Set the condition to check if the product type is “reel”.
- If true, proceed to the next step for YouTube upload.
This ensures only the desired content is shared with your audience on YouTube.
5. Uploading Captured Reels to YouTube
The final step is to upload your filtered Instagram reels to YouTube using Pabbly Connect. Navigate to the YouTube integration section and click “Sign in with Google” to connect your YouTube account.
Once connected, you’ll need to map the media URL from your Instagram post to the YouTube upload fields. This includes the video title and description, which can be the same as your Instagram caption. Set the visibility to public to share your content widely. Finally, click “Save and Send Test Request” to complete the upload process.
Using Pabbly Connect, you can create viral Facebook posts using AI efficiently. By automating the integration between Instagram and YouTube, you save time and enhance your social media presence. This streamlined process allows you to focus on content creation while Pabbly Connect handles the posting.
