1. Introduction to Pabbly Connect for Building the Complaint Portal
To build an online complaint portal, you will primarily use Pabbly Connect. This platform enables seamless integration between various applications like Pabbly Studio and Voice Grid. Start by visiting the Pabbly website and signing up or logging in.
Once you’re in, you can access all Pabbly applications. The first step is to navigate to Pabbly Studio, which is essential for creating your complaint portal. This application allows you to build functional apps without coding.
2. Creating the Voice Grid Application in Pabbly Studio
In Pabbly Connect, click on the “Create Application” button in Pabbly Studio. Name your application “Voice Grid” and hit “Create”. This sets up the foundation for your complaint portal.
Next, you will define the purpose of your app. Use the prompt section to describe its features. Here are key aspects to include:
  • Complaint submission by citizens
  • Categorization by departments
  • Complaint tracking and escalation
  • Visual consistency with a clean UI
Once you have described all functionalities, submit the prompt. Pabbly Studio will then generate your Voice Grid application based on these specifications.
3. Setting Up User Authentication in Voice Grid
After your application is created using Pabbly Connect, the next step is to implement user authentication. This is crucial for allowing users to log in and access the complaint management system.
In the Voice Grid interface, users will need to create an account. This process gathers essential information to facilitate login. Ensure that the interface is user-friendly, guiding users through the registration and login steps.
Once logged in, users will see a dashboard summarizing their complaints. This dashboard is designed to provide a quick overview of the status of their complaints, including:
  • Total complaints submitted
  • Pending complaints
  • Resolved complaints
4. Complaint Submission and Tracking Features
Using Pabbly Connect, you can set up features for users to submit complaints easily. The complaint submission form should allow users to describe their issues and select relevant categories.
When users submit a complaint, they receive a unique reference number. This number is crucial for tracking the status of their complaints. The tracking feature allows users to filter their complaints by status, department, and priority.
Each complaint’s details, including the current status and timeline, are easily accessible. Users can view the progress of their complaints, which helps build transparency and trust in the system.
5. Implementing Analytics and Statistics in Voice Grid
Finally, you can leverage Pabbly Connect to integrate analytics features into your Voice Grid application. This allows you to display overall statistics regarding complaints.
The analytics dashboard should summarize key metrics such as:
  • Total complaints received
  • Complaints resolved
By providing this information, users can gain insights into the complaint resolution process, enhancing accountability and efficiency.
In this tutorial, you learned how to build an online complaint portal using Pabbly Connect, Pabbly Studio, and Voice Grid. This process enables efficient complaint management and tracking, enhancing user experience and transparency.
