To begin integrating Pabbly, Pabbly Studio, MediStock, Publit Studio, and My Medic Stock, you need to access Pabbly Connect. Start by opening your web browser and navigating to pabbly.com.
Once on the homepage, click on the “Sign Up Free” button if you’re a new user. If you already have an account, simply log in to your dashboard. After logging in, locate the option for Pabbly Connect and click on it to access the integration interface.
2. Creating Your Application in Pabbly Studio
After accessing Pabbly Connect, you will need to create your application. Click on the “Create Application” button and name it “MediStock” to represent your pharmacy inventory management system.
  • Click on the “Create” button to initiate the application setup.
  • Once created, you will enter the Pabbly Studio interface.
In the Pabbly Studio interface, you can start designing your application. You will input various specifications and functionalities that you want for MediStock, ensuring it meets your pharmacy’s needs.
3. Designing Your MediStock Application
To design your MediStock application, you will describe the visual and functional requirements. In Pabbly Connect, you can provide a visual reference by uploading a screenshot of the desired user interface.
After uploading, you will answer a series of questions regarding the app’s design. Specify the color scheme, layout, and any specific functionalities you want to include. This helps Pabbly Studio understand your vision for the application.
  • Choose colors like deep blue and green for a professional look.
  • Ensure to mention alerts for low stock and expiration dates.
This detailed description allows Pabbly Connect to create a more accurate and functional application for your pharmacy management needs.
4. Implementing User Authentication
Once your application design is ready, the next step in Pabbly Connect is to implement a user authentication system. This feature allows pharmacy staff to create accounts and log in securely.
To set up authentication, navigate to the user management section in your MediStock app. Here, you will create a registration form where users can input their details to create an account. After filling in the required fields, click the “Create Account” button.
With user authentication in place, your pharmacy staff can now access the inventory management features securely, ensuring that only authorized personnel can view sensitive information.
5. Managing Inventory with MediStock
After setting up user authentication, you can now focus on managing your inventory using Pabbly Connect. The application allows you to track stock levels, expiration dates, and supplier details effortlessly.
The inventory management section provides a clear overview of all medications, including quantities and expiration dates. You can also add new products and update existing stock through a user-friendly interface.
  • Easily update stock levels as new shipments arrive.
  • Set alerts for low stock and nearing expiration dates.
This streamlined approach to inventory management not only saves time but also helps ensure that your pharmacy runs smoothly, with Pabbly Connect serving as the backbone of your operations.
In this tutorial, we explored how to integrate Pabbly, Pabbly Studio, MediStock, Publit Studio, and My Medic Stock using Pabbly Connect. By following these steps, you can effectively manage your pharmacy inventory and streamline operations for better efficiency.
