1. Access Pabbly Connect to Start Building Your Job Board
To build your job board platform, the first step is to access Pabbly Connect. Start by opening a new tab and navigating to pabbly.com. Here, you will find an option to sign up or log in.
If you are a new user, click on the “Free Sign Up” button, enter your details, and activate your free trial. As an existing user, simply log in to your account. Once inside, you will see all the applications available, but today, we will focus on Pabbly Connect and Pabbly Studio.
2. Create Your Job Board Application Using Pabbly Studio
After logging into Pabbly Connect, the next step is to create your job board application. Click on the “Create Application” button on the dashboard. You will then be prompted to name your application.
  • Name your application as “Higher Hub”.
  • Click the “Create” button to proceed.
Once you have created your application, you will be directed to the Pabbly Studio interface. Here, you can paste the application prompt that defines what your job board will include. This prompt will guide Pabbly Studio in designing your application.
3. Design Your Job Board with Pabbly Studio
In Pabbly Studio, you can specify various features for your job board. The prompt should include elements like user authentication, job browsing, job posting, application tracking, and user settings. This detailed input will help Pabbly Connect create a comprehensive job board.
For the aesthetics, choose a warm golden-yellow theme instead of the traditional blue. This visual identity will make your platform more inviting while maintaining a professional look. Once you have finalized your design, click on the “Submit” button to send your request to Pabbly Studio.
  • Customize the login screen with email and password fields.
  • Add options for new users to create an account.
  • Ensure user profiles cater to both job seekers and employers.
After submitting, Pabbly Studio will start processing your request. You can sit back and relax while it builds your application.
4. Explore Features of Higher Hub
Once your application is ready, you will see a sleek login screen. This interface allows users to log in and track their job applications. The platform is designed for both job seekers and employers, providing tailored experiences for each.
Job seekers can create profiles, browse job listings, save opportunities, and apply for jobs. Employers can post job listings, manage applications, and review candidates. This dual functionality is facilitated by Pabbly Connect, which ensures that both sides of the job market are connected seamlessly.
  • Job seekers can filter jobs based on location, employment type, and experience level.
  • Employers can track candidates through various application stages.
  • The platform allows users to save jobs for future reference.
This interconnected platform is a game-changer for job hunting and recruitment, all thanks to the capabilities of Pabbly Connect.
5. Final Steps to Launch Your Job Board
As you finalize your job board, you can preview how it looks on various devices. This feature is crucial for ensuring that your platform is user-friendly across all screen sizes. Simply click on the preview button to see your application in action.
To share your application, you can copy the provided link and distribute it to potential users. If you want to use a custom domain instead of the default Pabbly domain, you can easily link your domain through the settings.
  • Ensure all functionalities are working as intended.
  • Test the application thoroughly before launching.
  • Launch your job board and start connecting job seekers with employers.
With the help of Pabbly Connect, you have successfully built a job board platform in under 30 minutes without writing any code. This streamlined process makes it easy for anyone to create a professional job board.
In this tutorial, we demonstrated how to build a job board platform using Pabbly Connect and Pabbly Studio. With these tools, creating a seamless integration for job seekers and employers is easier than ever!
