1. Setting Up Pabbly Connect for Email Automation
To start automating your email responses, first access Pabbly Connect. This platform allows you to create workflows that integrate various applications seamlessly. Begin by signing up or logging in to your Pabbly Connect account.
After logging in, create a new workflow by selecting the “Create Workflow” option. Name your workflow appropriately, such as “Email Automation with GPT-6 Astra”. This step is crucial as it sets the foundation for your automation process.
2. Connecting Gmail to Pabbly Connect
In this step, you will connect your Gmail account to Pabbly Connect. This integration allows Pabbly to monitor incoming emails and trigger actions based on specific criteria. Click on “New Connection” and log in using your Google account.
- Choose the Gmail account you want to integrate.
- Select the Label ID for filtering incoming emails.
- Pick the content type as “Plain Text” or “HTML” based on your needs.
Once you’ve set these options, click on “Save and Send Test Request”. This action will trigger a test to ensure that Pabbly Connect is properly connected to your Gmail account, allowing it to capture new emails effectively.
3. Integrating GPT-6 Astra with Pabbly Connect
Next, you will integrate GPT-6 Astra into your workflow using Pabbly Connect. This integration enables the AI model to generate automated responses to incoming emails. Add a new action step and select OpenAI ChatGPT as the application.
To establish this connection, you will need an API token from OpenAI. Go to the OpenAI API keys page, create a new key, and paste it into the required field in Pabbly Connect. After this, select the model, specifically GPT-6 Astra, for generating responses.
- Set the prompt for the AI, indicating it should respond professionally to customer inquiries.
- Use mapping to dynamically include the email subject and content in the prompt.
- Click “Save and Send Test Request” to see the generated response.
With this integration, every time an email arrives, GPT-6 Astra will create a tailored response based on the email content, significantly enhancing your customer interaction capabilities.
4. Sending Responses Back to Gmail
The final step involves sending the AI-generated responses back to your Gmail account using Pabbly Connect. Add another action step in your workflow to facilitate this. Select Gmail as the action application and configure the necessary fields.
In this setup, specify the recipient’s email address, which can be dynamically mapped from the previous steps. Ensure that the email content is set to “Plain Text” and include the response generated by GPT-6 Astra. After configuring these fields, click on “Save and Send Test Request” to finalize the setup.
Using Pabbly Connect, you can effectively automate email responses with GPT-6 Astra, streamlining your customer interactions. This integration not only saves time but also ensures that all inquiries are addressed promptly and professionally.
