1. Accessing Pabbly Connect
To start integrating WhatsApp with OpenAI, first, you need to access Pabbly Connect. This platform allows you to create automated workflows that connect various applications seamlessly.
Begin by signing up at the official Pabbly website. After signing up, you will receive 100 free credits each month, perfect for testing your integrations. Once logged in, navigate to the Pabbly Connect dashboard to set up your integration.
2. Creating Your WhatsApp Assistant with Pabbly Connect
After accessing Pabbly Connect, the next step is to create your WhatsApp Assistant. This is done through the Pabbly Chartflow feature, which allows you to automate WhatsApp interactions.
Click on the “Add Assistant” button to begin. You’ll need to provide a descriptive name for your assistant. Once named, select the instruction type as “AI Agent” to generate rules for how your assistant will respond. This ensures accurate and relevant answers for user queries.
  • Select the temperature setting to control response creativity.
  • Choose the model provider, typically OpenAI.
  • Input your API key from the OpenAI platform.
These settings will help tailor your assistant to provide the best user experience. After configuring these options, click on the “Connect” button to finalize your setup.
3. Setting Up Your Knowledge Base for Effective Responses
In this section, you will upload your knowledge base, which is crucial for your assistant’s performance. The knowledge base contains specific information that the assistant will use to answer queries accurately.
To upload your knowledge base, ensure it contains relevant details about your housing society, such as maintenance support, parking policies, and security information. You can create this document using Google Docs or any text editor, saving it as a PDF or .txt file.
  • Ensure your file is under 90 MB.
  • Accepted formats include .txt and PDF.
  • Limit images in PDFs to 10 pages.
Once your file is ready, upload it to Pabbly Connect. This will enable your assistant to provide tailored responses based on the information you’ve included.
4. Finalizing Your Assistant Setup in Pabbly Connect
After uploading your knowledge base, you need to finalize the assistant’s settings. This includes customizing the assistant’s interface and enabling auto-replies for user queries.
In the assistant settings, you can add header and footer messages, as well as set up stop keywords that will pause the assistant’s responses, requiring human intervention. Additionally, configure retry attempts to ensure your assistant tries to respond multiple times if it encounters issues.
  • Enable auto-replies to automate responses.
  • Select your contact list for interaction.
  • Save all settings to ensure functionality.
Once everything is set, click the “Save Assistant” button to complete your setup. Your WhatsApp assistant is now ready to handle queries effectively using Pabbly Connect.
5. Conclusion
In this tutorial, we explored how to integrate WhatsApp with OpenAI using Pabbly Connect. By following these steps, you can create a powerful AI assistant that efficiently responds to resident queries.
Utilizing Pabbly Connect not only streamlines communication but also enhances user experience by providing instant answers. This integration is essential for housing societies looking to improve their operational efficiency.
For more detailed guidance, ensure to follow the steps outlined above for a successful setup.
