1. Setting Up Pabbly Connect for WhatsApp AI Integration
To begin, you need to access Pabbly Connect to set up your WhatsApp AI assistant. First, create an account on Pabbly Connect if you don’t already have one. Once logged in, navigate to the dashboard where you can start creating your integration.
Ensure you have your WhatsApp number ready to integrate. This integration allows your hotel to manage booking inquiries seamlessly. Follow these steps to set up:
  • Create an account on Pabbly Connect.
  • Log in and access the dashboard.
  • Add your WhatsApp number in the settings.
After completing these steps, you are ready to create a WhatsApp AI assistant that will handle room booking inquiries efficiently.
2. Creating the WhatsApp AI Assistant in Pabbly Connect
Next, within Pabbly Connect, you will create your WhatsApp AI assistant. Click on the assistant feature and select to add a new assistant. Name it descriptively, such as ‘Hotel Booking Assistant’. This name will help in identifying the assistant later.
Once named, you will need to select the instruction type. Choose ‘AI Agent’ to set the behavior of the assistant. This step is crucial as it defines how the AI will respond to customer inquiries. Adjust settings like temperature to control the creativity of responses. A temperature setting of 0.5 is recommended for balanced responses.
  • Select the AI model provider as Open AI.
  • Choose the AI model variant, such as GPT-4 Mini.
  • Input your Open AI API key to connect.
With these configurations, you are effectively setting up the AI assistant to cater to customer booking inquiries accurately.
3. Uploading the Knowledge Base for Your Assistant
The next step involves uploading a knowledge base to your assistant in Pabbly Connect. This knowledge base acts as the information repository for your assistant, enabling it to provide accurate responses to customer queries. Create a knowledge base file containing details about room types, amenities, and booking policies.
To upload, click on the option to add a new file and select your prepared knowledge base document. Ensure that the file is in .txt or PDF format and does not exceed 90 MB. Once uploaded, your assistant will be able to access this information to respond intelligently.
  • Create a knowledge base file using Google Docs or similar tools.
  • Ensure the file contains all relevant hotel information.
  • Upload the file in the correct format.
Having a robust knowledge base is essential as it empowers your assistant to handle inquiries effectively, thus enhancing customer satisfaction.
4. Customizing Your Assistant’s Interface in Pabbly Connect
After uploading the knowledge base, you can customize the interface of your WhatsApp AI assistant using Pabbly Connect. This includes setting headers, footers, and the initial greeting message. For instance, you might want to set the header as ‘Grand Horizon Hotel and Resort’ to personalize responses.
Additionally, adjust the footer to include booking policies and other relevant links. This customization ensures that your assistant communicates in a way that reflects your hotel’s branding and provides essential information to customers.
  • Set a header for your assistant to personalize interactions.
  • Add a footer with booking policies and contact information.
  • Customize initial messages to greet users effectively.
This level of customization not only enhances user experience but also ensures that your assistant aligns with your hotel’s operational standards.
5. Enabling Auto Replies for Customer Queries
Finally, enable the auto-reply feature in Pabbly Connect to ensure that your assistant can respond to customer inquiries instantly. Navigate to the inbox settings and enable the AI auto-reply settings. This allows your assistant to automatically respond to all contacts you have set up.
Make sure to save these settings to activate the assistant. By doing so, your WhatsApp AI assistant will be ready to handle inquiries 24/7, providing a seamless experience for potential guests.
  • Enable AI auto-reply settings in inbox settings.
  • Select the contacts for which the assistant will respond.
  • Save the settings to activate the assistant.
This ensures that your hotel can manage inquiries effectively, enhancing customer engagement and increasing booking rates.
In this tutorial, we explored how to handle room booking inquiries using WhatsApp AI integrated with Pabbly Connect. By following these steps, hotels can streamline customer interactions and improve booking efficiency. Implementing this solution not only enhances customer service but also boosts the likelihood of converting inquiries into confirmed bookings.
