To start integrating Facebook leads into HubSpot, the first step is to access Pabbly Connect. Open your web browser and navigate to pabbl.com/connect.
If you are a new user, click on the “Sign up for free” button located in the top right corner. This grants you access to a free trial of Pabbly Connect, which includes up to 100 tasks for lead management.
Once you are logged into Pabbly Connect, navigate to the workflow builder. This is where you will set up the automation process.
- Click on the “Add Trigger” button.
- Search for “Facebook” and select “Facebook Lead Ads”.
- Choose the event as “New Lead” and click on “Connect”.
After connecting, select your Facebook page and lead form for which you want to automate the process. Click “Save and Send Test Request” to capture the response from the lead form.
3. Capturing Lead Details from Facebook
To capture lead details, you need to test the integration by submitting a lead form. Open the Meta for Developers page and navigate to the Lead Ads Testing Tool.
- Select the page and lead retrieval product.
- Fill in the lead form with test data.
- Submit the form to generate a new lead.
Once submitted, return to Pabbly Connect to see if the lead details have been captured successfully. This confirms that your connection is working properly.
4. Adding HubSpot as an Action Step
Now that you have captured the lead details, it’s time to add HubSpot as an action step in your workflow. Click on “Add New Action Step”.
- Search for “HubSpot CRM” and select it.
- Choose the event as “Create Contact” and click on “Connect”.
- Log in to your HubSpot account if prompted.
Map the lead details from the previous step to the respective fields in HubSpot. This ensures that every new lead is automatically added as a contact in your HubSpot CRM.
After mapping the fields, click on “Save and Send Test Request” to create a new contact in HubSpot. This step verifies that the integration is functioning correctly.
Go back to your HubSpot account and refresh the contact list. You should see the new contact with the details you entered in the lead form. This confirms that Pabbly Connect has successfully automated the process.
In this tutorial, we explored how to integrate Facebook leads into HubSpot using Pabbly Connect. This automation saves you time and ensures that your leads are captured efficiently. Try this setup to streamline your lead management process!
