1. Introduction to Pabbly Connect for Lead Capture
Pabbly Connect is essential for capturing every paid advertising lead seamlessly. By integrating Google Ads with Aweber through Pabbly Connect, businesses can automate their lead nurturing process effectively.
To get started, visit the Pabbly Connect website and sign up for a free account. This allows you to explore the features and set up automation for your Google Ads leads.
2. Setting Up Google Ads Integration with Pabbly Connect
To set up the integration, first, log into your Pabbly Connect account. Then, click on the ‘Add Trigger’ button and search for Google Lead Ads. Choose the event as ‘New Lead Form Entry’ to initiate the workflow.
  • Select Google Lead Ads as the trigger application.
  • Choose ‘New Lead Form Entry’ as the event.
Next, go to your Google Ads campaign and create a lead form. Paste the webhook URL into the lead delivery settings to establish a connection between Google Ads and Pabbly Connect.
3. Testing the Connection Between Google Ads and Pabbly Connect
After setting up the lead form, it’s crucial to test the connection. Send test data from Google Ads to ensure that Pabbly Connect captures the information correctly.
Once the test data is sent, return to Pabbly Connect. You should see the captured test data as a webhook response. This confirms a successful connection between Google Ads and Pabbly Connect.
4. Integrating Aweber with Pabbly Connect
Now that Google Ads is connected, it’s time to integrate Aweber. Click on ‘Add Action Step’ in your Pabbly Connect workflow and select Aweber as the action application.
  • Choose ‘Add or Update Subscriber’ as the action event.
  • Connect your Aweber account to Pabbly Connect.
  • Map the lead details from the previous step to the correct fields in Aweber.
This mapping is essential for ensuring that the leads are captured accurately in your Aweber email list. Once mapped, click ‘Save and Send Test Request’ to verify the integration.
5. Conclusion: Automate Your Lead Capture with Pabbly Connect
Using Pabbly Connect to integrate Google Ads with Aweber streamlines your lead capture process effectively. By automating this workflow, you ensure that leads are nurtured promptly without manual intervention.
Start capturing every paid advertising lead in one place with Pabbly Connect today. This automation not only saves time but also increases your chances of converting leads into customers.
