To start integrating Pabbly, Pabbly Chatbot, and Pabbly Plus, you first need to access Pabbly Connect. This platform serves as the central hub for managing your integrations effectively.
Log in to your Pabbly account, navigate to the Pabbly Connect dashboard, and create a new workflow. This will allow you to set up automated tasks between the applications seamlessly.
2. Setting Up Pabbly Chatbot
In this section, we will set up the Pabbly Chatbot to automate WhatsApp interactions. Using Pabbly Connect, you can create a chatbot that welcomes potential clients and gathers their requirements.
  • Access the Pabbly Chatbot builder.
  • Name your workflow for easy identification.
  • Select the trigger event as “Keyword” to initiate the chatbot.
Once you have set up the trigger, you can define the keywords that will activate the chatbot. This ensures that whenever a client sends a specific keyword on WhatsApp, the chatbot responds automatically.
3. Creating the Chatbot Flow
Next, we will create the flow of the chatbot using Pabbly Connect. This flow will guide the conversation with your clients, ensuring they receive relevant information about your services.
Begin by adding a welcome message that introduces your agency. You can also include media such as images to make the interaction more engaging. After this, set up quick reply buttons to help clients navigate through the conversation.
  • Add a text button for “Get a Consultation”.
  • Create another button for “Contact Our Team”.
  • Link these buttons to the respective responses in your chatbot flow.
This structured flow allows clients to easily access the information they need, enhancing their overall experience with your agency.
4. Collecting Client Information
In this step, we will configure the chatbot to collect essential client information using Pabbly Connect. This is crucial for understanding client needs effectively.
Once the client selects a service, the chatbot should prompt them to share their name and other details. To do this, add a question node and specify the required fields such as name, budget, and contact number.
  • Set the question format to ensure the correct data type.
  • Define the number of attempts for clients to respond correctly.
  • Provide error messages for incorrect inputs.
This method allows you to gather detailed information from clients, which can be used to tailor your services to their needs.
5. Finalizing the Chatbot Flow
Finally, we will finalize the chatbot flow using Pabbly Connect. This step ensures that all elements are connected and functioning as intended.
After setting up the collection of client information, add a final response message that thanks the client for their input. This message should include all the details they provided, ensuring a personalized touch.
  • Incorporate dynamic fields to display client inputs in the final message.
  • Save the flow to ensure all changes are applied.
By completing these steps, your chatbot is now ready to interact with clients on WhatsApp, providing them with a seamless experience.
This tutorial demonstrated how to integrate Pabbly, Pabbly Chatbot, and Pabbly Plus using Pabbly Connect. By following these steps, you can automate your WhatsApp interactions and enhance client engagement effectively.
