To begin, access Pabbly Connect by visiting the Pabbly website and signing up. This platform allows you to integrate various applications seamlessly, including WhatsApp. After signing up, you will receive 100 free credits monthly to explore its features.
Once logged in, navigate to the dashboard and select the option to create a new workflow. This is where you will set up the integration between WhatsApp and your AI assistant. Pabbly Connect acts as the central hub for managing this process.
2. Creating Your AI Assistant
In this step, you will create an AI assistant using the Pabbly Chatflow feature. Click on the ‘Add Assistant’ button and give your assistant a descriptive name, such as “Dealer AI Assistant for WhatsApp.” This naming is crucial for easy identification later.
- Select the instruction type as “AI agent”.
- Customize the instructions if needed.
- Set the temperature for response creativity.
After setting these parameters, your AI assistant will be ready to understand and respond to customer inquiries effectively. The Pabbly Connect platform ensures that your assistant can provide tailored responses based on user input.
3. Configuring API Settings for Your Assistant
Next, you need to configure the API settings for your assistant in Pabbly Connect. This involves generating an API key from your OpenAI account. Navigate to the OpenAI API keys page and click on “Create New Key” to generate your token.
Once you have your API key, paste it into the designated field in the assistant settings within Pabbly Connect. Make sure to click the “Connect” button to establish the link. This API integration allows your assistant to access advanced AI capabilities for better customer interaction.
4. Uploading Knowledge Base for Accurate Responses
To enhance the effectiveness of your AI assistant, upload a knowledge base file. This file should contain all the essential information related to your business. In Pabbly Connect, click on the “Add New File” option and select your knowledge base document, ensuring it is in PDF or text format.
- Ensure the file size is under 90 MB.
- The accepted formats are .txt or .pdf.
With the knowledge base uploaded, your assistant can now provide accurate responses based on specific queries. This integration is crucial for maintaining high customer satisfaction through Pabbly Connect.
5. Finalizing Your Assistant and Settings
After configuring your assistant, you can customize its appearance and settings in Pabbly Connect. Change the heading, subheading, and initial message to reflect your brand. You can also adjust the styling to make your assistant visually appealing.
Finally, don’t forget to enable the AI auto-reply settings in the inbox settings of Pabbly Connect. This will ensure that your assistant is active and ready to respond to customer inquiries. Save all settings, and your WhatsApp assistant is now fully operational.
In this tutorial, we demonstrated how to integrate WhatsApp with Pabbly Connect to create a responsive AI assistant. By following these steps, you can automate customer interactions effectively, ensuring timely responses and improved customer satisfaction.
