To start integrating WhatsApp with Pabbly Connect, visit the Pabbly website. Click on the “Sign Up for Free” button if you are a new user. This will allow you to create your account and access the platform’s features.
Once signed up, log in to your Pabbly account. You will see the dashboard where you can access various applications. Click on the “Pabbly Connect” option to proceed with the integration process.
2. Setting Up WhatsApp Broadcast with Pabbly Connect
After accessing Pabbly Connect, navigate to the “Broadcast” section. Here, you can create a new WhatsApp broadcast message. This feature allows you to send messages in bulk to your customers efficiently.
- Click on the “Add Broadcast” button.
- Select the broadcast type as “Broadcast Campaign”.
- Name your broadcast, e.g., “New Grocery Deal”.
This setup allows you to efficiently manage your messaging campaigns. Ensure that you have a pre-approved message template ready for use.
3. Creating a Contact List in Pabbly Connect
Next, you need to create a contact list for your broadcast. Using Pabbly Connect, you can upload contacts directly from a CSV file or manually add them. This step is crucial for ensuring that your messages reach the intended recipients.
To upload a contact list, follow these steps:
- Go to the “Contacts” section in Pabbly Connect.
- Click on “Add Contact” and select the option to upload a CSV file.
- Ensure your CSV file is formatted correctly with all necessary details.
Once your contacts are uploaded, you can select them for your broadcast campaign. This ensures that your messages are sent to the right audience.
4. Creating a Message Template for WhatsApp
Before sending out your broadcast, you need a message template. With Pabbly Connect, you can create and manage these templates easily. This template will be used to format your messages consistently.
To create a message template:
- Navigate to the “Templates” section in Pabbly Connect.
- Click on “Create New Template” and fill in the necessary details.
- Make sure to upload any media files needed for the template.
After creating the template, you can preview it to ensure everything looks good before sending it out to your contacts.
5. Testing and Scheduling Your Broadcast
Once you have set up your broadcast message and selected your contact list, it’s time to test the broadcast using Pabbly Connect. This ensures that your messages are correctly formatted and delivered.
To test and schedule your broadcast:
- Click on the “Test Broadcast” button to send a test message to your WhatsApp number.
- If successful, proceed to schedule your broadcast by selecting a date and time.
- Finally, click on the “Schedule Broadcast” button to confirm.
This testing phase is crucial to ensure that your audience receives the message as intended. Once confirmed, your broadcast will be scheduled for the selected time.
Integrating WhatsApp with Pabbly Connect allows businesses to efficiently send bulk messages. By following the steps outlined in this tutorial, you can streamline your communication processes and enhance customer engagement.
